Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Bead locked CCW Classics
Old 04-03-2016, 03:59 PM
trayack
trayack's Avatar
Default Bead locked CCW Classics
I'd been on the fence about adding a beadlock to my CCW Classics. After talking things over with my chassis builder we both decided that at my current level and setup I've got to be rotating the rim in the tire so I bit the bullet.
On Friday morning I drove down to Exstreme Fab in North Haven CT. As promised they installed the beadlocks in about an hour while I went and grabbed lunch.
As its a 16 inch setup I went with the Ultra-lite locks to keep the weight increase down as much as possible.
Here's the ring welded on the rim, and you'll see the reliefs to help with the weight. Every edge is finished and smoothed too.
The ring has also been relief cut, and you can see the knurling on the inner side.
Here's the finish product. Super quality job, and the total cost for two 16 Ultra-lites in black was $850. Not cheep by any means but very reasonable once you see what all is involved. Just waiting on some High-Tack for the inner bead to mount things up.
- Travis
Old 04-03-2016, 07:10 PM
C5 Pete
AMP Racing
Support Corvetteforum!
C5 Pete's Avatar
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Wow. That looks great!
How much weight did it add to the wheel?
Old 04-03-2016, 10:14 PM
trayack
trayack's Avatar
Not sure yet, haven't had them on a scale. Honestly, with the relief cuts in the inner and outer rings most of the weight increase will be from the 20 ring bolts.
- Travis
Old 04-04-2016, 01:35 PM
trayack
trayack's Avatar
They weight in at 21lbs now. Not sure what the stock weight was....
- Travis
Old 04-09-2016, 02:52 AM
trayack
trayack's Avatar
Finally had a few minutes to mount the tires back on. Lock on the outside and Permatex High-Tack on the inner bead.
- Travis
Old 04-09-2016, 06:59 AM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Old 04-10-2016, 02:13 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Nice
Old 11-14-2016, 06:10 PM
JeremiahsC5
JeremiahsC5's Avatar
Sick set up! Might ship my CCW's up or go with Mac Fab here in NC.
Old 10-03-2018, 11:24 PM
Z06_NV
Z06_NV's Avatar
Dream set up right there, GLWS sick car buddy!!!!
To Bead locked CCW Classics
Quick Reply: Bead locked CCW Classics
