Gelcoat incompatable
going to start a 1971 coupe body work prep for paint by me. from the forum I gather that the best thing to do is to gelcoat the entire body after bodywork then prime and paint. one of Ecklers gelcoat warnings is not to apply over SMC. I have 2 repair panels on the car from a previous owner and I don't know what they are made of and I think 1971 they started using SMC. How can I identify SMC.
Grayish-white panel that has a marbleized look to it with some dark streaks running in it. IT will look completely different than the way the spare tire carrier looks on the inside of the tub.
DUB
DUB
If you are still concerned...post a photo of what you have.
DUB
Is the panel shiny black on the outside and a rough texture on the inside...then this is a hand-laid fiberglass part and it is already gelcoated.
Why don't you post a photo of both sides so there is no misunderstanding...at at least where you got the part and the pat number.
DUB
DUB
DUB
DUB
Thanks!
What panel is it and are you planning on using it or them if they are both hand-laid fiberglass parts????
DUB
DUB
Are you planning on sectioning in this half fender if that is what it is????
DUB
both pieces are glassed onto the body I was just asking on what type of gelcoat would work on the body. I was afraid that one of the repair pieces was SMC but you pointed out that they are not. so I guess when I am ready I can use what ever brand gelcoat I want. probably Evercoat polyester that requires VPA.
Best of luck to you
DUB
