Seat latch problem
Seat latch problem
Crappy pictures I know but, what holds the chrome button in? The sliding parts seem to bind at the top. What type lube should I use or? All past experiences welcome
Received 2,878 Likes
Hi c,
There is a single screw that threads into the body of the chrome plated plastic button from the back side of the seat lock strap assembly.
It appears the 'shank' on the back of the button that the screw tightens into has been broken off the button.
It's shown in the Seats section of the AIM if you have one.
Regards,
Alan
Regards,
Alan
Hi c,
Yup. That's it.
The long thin 'pin' that's still there on the back of the button prevents it from rotating slightly in the chrome plated bezel that surrounds it.
Regards,
Aan
Yup. That's it.
Regards,
Aan
Thanks Alan I've got it all apart. Trying to figure out what to lube the slide with. I've got some silicone lube with a release agent I'm gonna try. I'm gonna try some JB weld because the little bit was holding it, and a new one prolly worse then this one
