missing part
missing part
Can someone please tell me where I can find this part. A plastic piece that goes in front of the radiator. It helps with diverting the air through the front of the radiator instead of over the engine. It bolts under the metal piece that goes across the front. I took a picture of what it looks like on another 82 vette. You cannot buy this from Corvette parts dealers. Thanks for any help.
Dunno about an 82, but my 78 has a "high density shroud foam seal" when I figured it was missing, I used some foam pipe insulator in the gap as short term fix. Never overheated.
Dementer sole survivor
Received 6,294 Likes
2016 C3 of Year Finalist
https://www.paragoncorvette.com/p-34...-seal-kit.aspx
https://www.paragoncorvette.com/p-35...-seal-kit.aspx
Seal kit from paragon
Not knowing the name makes it harder to search.....
missing part
missing part
My car doesn't overheat but I just want it for originality purposes and also it may help it as far as the flow of air is concerned.
Is this what you're looking for? If so it's variously called "front intake duct" and "center intake duct" and is part of the cold air intake system used from '76 - 82. There are two versions: One used from '76 - '78 had a single inlet; the other used in '78 with the L82 engine and on all engines '79+. Unfortunately they seem to be out of stock at all the vendors.
Presuming your original cold air intake has been removed I don't know if that part serves any purpose whatsoever as the fan shroud does the job of ensuring that air passes through the radiator.
Occasionally, you can find those pieces on eBay.
Is this it in front of the caution label?
http://www.ebay.com/itm/1982-C3-Corv...-/301485222099
I think that part might go in the hood. I think what you want is called an upper radiator air deflector or dam. I found some from 94 to present with that name so its got to be close
Where do you live. Check craigslist
Heres aguy around me parting out an 82
http://boston.craigslist.org/sob/pts/5839343705.html
Heres a corvette junk yard
http://boston.craigslist.org/nos/ptd/5839002362.html
Heres another, he lists all sorts of stuff
http://nh.craigslist.org/pts/5783568112.html
Hope im helping
Hope im helping
