Spreader bar
Old Aug 3, 2008 | 10:00 AM
Phil Zell's Avatar
Phil Zell
Default Spreader bar
Anybody got any pros, cons, on spreader bars. Will they help with alignment issues?
Thanks to all
Old Aug 3, 2008 | 10:06 AM
Gordonm's Avatar
Gordonm
If the alignment is off it won't help it out. It will stiffen up the front end of the car. I have one on my car and it helped stiffen up the front. It ties the two shock towers together so if there is any flex in the frame this all but elimintes it.
Old Aug 3, 2008 | 10:46 AM
Durango_Boy's Avatar
Durango_Boy
Solid engine mounts help a lot too.
Old Aug 3, 2008 | 11:23 AM
Theiskell's Avatar
Theiskell
I installed one on my ’69 and could tell a huge diffrence.
Old Aug 3, 2008 | 12:57 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Old Aug 4, 2008 | 09:09 AM
pws69's Avatar
pws69
Old Aug 4, 2008 | 09:23 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Pics of the bar installed?
Old Aug 4, 2008 | 09:42 AM
Gordonm's Avatar
Gordonm
Here is mine. I have since put in a Dewitts and dual Spals but that did not interfere with the bar at all.
Old Aug 4, 2008 | 11:01 AM
Theiskell's Avatar
Theiskell
I made this one from parts at speedway for about 35 bucks
You can get all of the parts from speedwaymotors.com
Here are all of the part numbers needed
1170810L LH male hemi joint 9.99
1170810 RH male hemi joint 9.99
3159603 RH jam nut 1.99
3159604 LH jam nut 1.99
91034158-19 19” tie rod sleeve 10.99
The 19 at the end of the sleeve part number indicates the length, so if you need a 17” bar you would use 91034158-17
I made the mounting bracket out of two 8” long pieces of ¼” thick angle
Old Aug 4, 2008 | 11:22 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
Thanx Guys.
Old Aug 4, 2008 | 11:32 AM
c69vete's Avatar
c69vete
St. Jude Donor '07
Heres mine with the stock pulleys and flex fan.
Old Aug 4, 2008 | 07:20 PM
Phil Zell's Avatar
Phil Zell
So if I don't want to make my own, who's do you suggest?
Thanks for all the feedback
Old Aug 4, 2008 | 08:17 PM
wiseman79's Avatar
wiseman79
I used a VBP and could tell a difference in handling, also eliminated some rattles.
Old Aug 4, 2008 | 08:21 PM
Gordonm's Avatar
Gordonm
Mine is from VBP.
I do like the one Theiskell made though. Looks nice and cheaper too!
Old Aug 4, 2008 | 08:39 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Looks like using this the factory fan must be eliminated?
Old Aug 4, 2008 | 09:58 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
Not if you can build it yourself. I could have used the one I made even with the clutch fan.
Old Aug 4, 2008 | 10:14 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Originally Posted by c69vete
Great looking bar. I will be making one to fit my car. I have to find something to use my new plasma cutter and tig welder on!
It looks like time to change thsoe belts, before they leave you stranded. (don't you just love when someone posts a comment that has nothing to do with the thread?).
To Spreader bar
Old Aug 4, 2008 | 10:31 PM
SmokinBBC's Avatar
SmokinBBC
On my 70 BB, the only way that I am aware of installing a spreader bar is to eliminate the stock fan.
Old Aug 5, 2008 | 08:38 AM
c69vete's Avatar
c69vete
St. Jude Donor '07
It looks like time to change thsoe belts, before they leave you stranded. (don't you just love when someone posts a comment that has nothing to do with the thread?).[/QUOTE]
Thanks. That pic was 2 years ago and the belts have been changed.
I think the trick to making a spreader bar work with the stock pulleys is to lower the mounting point of the bar. My setup has the mounting point 1" below the centerline of the A-arm attaching bolts. That is why my mounting plates are 3/8X2" S/S flat stock.
Old Aug 5, 2008 | 06:40 PM
Brown78's Avatar
Brown78
I've already started and have located the web site. Question, this job can be done, without having to have the front end lined up again dose it. Do you think it would be OK to use 1/4" or 3/8" alum. instead of steel. How much movement will there be at the ends.
