C6 Corvettes for Sale Private Classifieds, Used C6 Corvettes For Sale, and Modified or Stock Corvettes
WTB: Built C6z/GS with powerglide and boost
Old 10-24-2016, 03:19 PM
MikePD
MikePD's Avatar
Default WTB: Built C6z/GS with powerglide and boost
Looking for a built and boosted C6z or C6 with a powerglide. If it doesnt have a glide i would still be open to the deal so i can just swap one in. Prefer twin turbo or single turbo setup. Must still retain A/C !!!!!!
Let me know what you have. Will travel. I am located in Texas!!!
Old 10-24-2016, 04:47 PM
AtomicBob
AtomicBob's Avatar
https://www.corvetteforum.com/forums...and-sport.html
Old 10-24-2016, 05:18 PM
MikePD
MikePD's Avatar
very nice car but i will have to pass man. good luck with sale
Old 10-25-2016, 07:02 AM
droptopsnake01
droptopsnake01's Avatar
Your car.
https://www.corvetteforum.com/forums/c6-corvettes-for-sale/3805869-2008-z06-f1x-powerglide-car-for-sale.html
Old 10-25-2016, 11:45 PM
MikePD
MikePD's Avatar
Originally Posted by droptopsnake01
Fran already sold that car
Old 10-25-2016, 11:46 PM
Frans96ss
Frans96ss's Avatar
St. Jude Donor '09
I have another
Old 10-25-2016, 11:48 PM
MikePD
MikePD's Avatar
Originally Posted by Frans96ss
I have another
i already know... seeing my options
Old 10-27-2016, 01:52 PM
MikePD
MikePD's Avatar
still looking!!!
Old 10-27-2016, 07:55 PM
Cheez
Cheez's Avatar
Reagor Dykes dealership has one in Lamesa Tx. It's a '13 vert, 427 w/ Edelbrock supercharger and auto swap done by RPM transmissions shop in Indiana.
Old 10-27-2016, 08:29 PM
DPW_
DPW_'s Avatar
this one I guess, http://www.reagordykesautogroup.com/...dcce2b206e.htm
Old 10-28-2016, 01:07 PM
MikePD
MikePD's Avatar
Originally Posted by DPW_
nah i said i wanted a built car lol.. thats just a stock vert with a blower and auto lol.
Old 10-28-2016, 06:01 PM
MikePD
MikePD's Avatar
ok doesnt have to have a glide in it but wanting a built 6 bolt motor,TT,c6z!!!
Old 11-05-2016, 11:06 PM
MikePD
MikePD's Avatar
bump still looking!!
Old 11-26-2016, 03:15 AM
gnx7
gnx7's Avatar
While this may not be a Corvette..... it does kick ***.
'93 Mazda RX-7: 2900lbs wet, LS9 block, K1 crank, Compstar rods, MAST LS3 heads, LS3 intake, 88mm T4 turbo (1400hp rating), Stainless works 1 3/4" headers, 2.25" s/s custom crossover, 3.5" downpipe, dual Tial 38mm wastegates, TreadStone intercooler, ID1600 injectors, dual Walbro 450's, Mustang 8.8" solid rear with Wavetrac LSD and 3.31 gears. GZ Motorsports vacuum pump, power steering, modified stock LS3 fuel rail with add'l crossover and rear 1/2" feed to look stock. Dual thick core radiator up front with Spal 12" fans plus a smaller rear mount radiator by the rear bumper with no fans in it. No cooling issues whatsoever. In 90* weather making a 1/2 mile pass it starts out in the low 180* coolant temp range and after a pass goes up to 195-200*.... by the time you get back to the pits its back down to low 180*. The cooling system really shines on this car making it a seriously streetable setup and never a worry about overheating.
Runs Holley Dominator EFI sytem plus with the T56 Magnum it simply drives great running a baby cam with mellow idle. Has a RaceShop chromoly roll bar with 6pt belt. Total sleeper with the e-cutout closed thru a super quiet 3" single exhaust. Open cutout terminates out the 3.5" downpipe that runs and exits just before the rear axle.
I also have a built stock case PG with billet internals, billet convertor, Tbrake, billet yoke 3.5" alum driveshaft, custom trans mount that I installed and after 3-4 miles removed it because I hated how it drove.
Our friend runs the exact same PG and convertor in his 2900lb LSx RX-7 and it has run low 8's for 3 years without issues.
Best of 9.35@163mph 2nd time out on T56 Magnum with lots left in it. That was on M/T ET Street DR 275/50/15 tires, 235/40/18 fronts, zero boost launch letting out the clutch slowly at 3000rpm and ramping in the boost by gear. Makes 1060rwhp/1070rwtq on 14psi and e85.
same pass different angle
Won Shift Sector RWD class 1/2 mile shootout 3 years in a row (every event) with major traction issues running the T56 Magnum. You could remove 150lbs from the car if you wanted to with very little effort. Runs consistent mid 190's it the 1/2 mile on a horrible airport runway surface surrounded by dirt fields and no traction control aside from boost by gear. Easily blows the tires off shifting into 5th gear at 20psi+ boost. In 4th you can finally pour in some good power and in 5th it's ***** the walls. It moves out in the top gears.
Fresh engine with zero miles (being installed after it gets out of the machine shop)
new zero mile T56 Magnum
1000 miles on the 8.8" solid rear conversion, fuel system, 1200hp version RXT clutch
Does 180mph in 4th gear
Should do 170mph+ on kill in the 1/4. It did 163mph with GTS76 turbo (1250hp rating) maxed out.
Has Davis Technologies traction control that needs to be dialed in. Keeps losing signal when we tried to set it up.
Easy 8 second car with decent launch running a T56 Magnum. Could go 7's with the powerglide and well prepped track is my guess. Our friend has a similar RX-7 with same turbo, same style and same builder of this built PG, 8.8" solid rear as well and it runs consistent 8.30's with a 1.4x 60'.
Has 13" brakes that stop the car from 200mph with no parachute pass after pass. Super stable at 200mph+
This car pretty much walks anything making 1500hp or less and rear wheel drive. The frontal area is tiny and the weight is low.
The engine was together for over 2 years and made easily 200 passes in the 1/4 and mostly 1/2 mile/freeway environment before I snapped the stock LS1 crank inside after showing off doing a 1-4th gear burnout and finally hooking up... then the crank snapped. Needed 2 rods and a new crank/rings/bearings. Everything else checked out fine. Never lost a head gasket or weeped any coolant in that time. The LS9 block allows for 120 ft/lbs of torque on the heads. MAST heads are thick deck quality units.
The vacuum pump could be moved to the driver side and a/c installed in it's place.
$45K obo
I have CF doors (-50lbs), CF rear hatch with lexan window (-35lbs), lithium battery (-25lbs), race seat (-15lbs) for additional cost.
Remove passenger seat (-35lbs), tar sound deadening under the carpet (-15lbs), and still look pretty much stock puts it at 2725lbs
Old 11-26-2016, 10:11 PM
trayack
trayack's Avatar
Not a C6/Glide but mine is available....just sayin.
- Travis
Old 11-29-2016, 10:44 AM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Might know someone interested.....boosted glide cars are not that common. I'll send him this link.
Old 12-01-2016, 03:46 PM
ibleedgreen
ibleedgreen's Avatar
Sent message.
Old 02-17-2017, 02:29 AM
sdunn
sdunn's Avatar
Default Built C6 Z06
Are you still looking for a built C6Z06? I have an 06 C6 Twin Turbo Z06 with a powerglide. My cell is 8325310034 or email sdunn2983@gmail.com
Thanks
Shawn
To WTB: Built C6z/GS with powerglide and boost
Quick Reply: WTB: Built C6z/GS with powerglide and boost
