Comp Gray painted rims, need help matching
i have a extra split spoke C6Z06 wheels that need to be refinished and i would like to paint them myself in COMP GRAY color
i dont have access to a paint booth or compressor so i will try to paint them with a spray can to see how it looks
is there a spray can that comes close to GM COMP GRAY color/texture? is so which brand and where do i buy some?
i am sure fellow CF members have done this, please post some pics of the finished product
I have tried about 7 different gray colors out of the can and they don't match well at all.
Consider buying some custom mixed paint and buying the bottles with aresol charges on the cap as an option.
Duplicolor T183 in a spray can from Advance Auto. Amother code is WA9243 or GM396.
Make sure you prep the surface properly. I used the red Scotchbrite pads for sanding. Followed by water, then enamel reducer for cleaning. Then a tack cloth to remove any lint or dust from the surface. Glide the tack cloth over the surface and don't press too hard. Wait ten to twenty minutes between coats depending on room temperature. Use the clear coat after base coat once the base coat looks covered properly. When spraying the clear coat on apply until it looks wet but not too much to avoid runs. I did this for my headlights when I replaced the lenses and it turned out great.
Correction. Use wax and grease remover for cleaning instead of enamel reducer.
I guess you want to do this yourself, but I would ask a local wheel refurbishing shop to spray them for you. I would double check this to make sure these numbers are right, but I believe the competition grey is paint code 87 or GM code WA9243.
I found two separate posts claiming the following are perfect matches for Competition Gray wheel paint:
Duplicolor BGM0534 which is Gray Mica
Duplicolor BGM0536 which is Gunmetal Mica
They can't both be right IMHO. I guess I am going to have to find a store with both in stock and drive the ZR1 there for an actual color cap comparison.
Biggest problem with rattle cans is the spray is often to thick and the tire needs to be elevated so all the extra spray dust does not come back up through the wheel sticking all over the wet paint.
You can get a professional finish.
This below was not even color sanded or buffed/polished.
I found this supplier online with WA9243 available in brush-on liquid bottles:
http://www.paintscratch.com/touch_up...at-WA9243.html
