Like Big Butts?
The reason we ask is that RPI Designs of Ohio has begun selling painted lower rear bumper covers for the C7 Stingray. Apparently, enough Corvette owners think that the OEM black lower fascia needs to be sprayed body color that RPI has taken up your cause. As a designer, I think you’d better be a fan of Sir Mix-A-Lot because if the entire rear is the same color it’s going to look MASSIVE.
You think maybe that’s why the lower fascia is blacked out? Whoa. Anyhow, the replacement part costs $800, $400 of which is refundable assuming you send in your original, perfect rear bumper.
You must be logged in to post a comment.
