Modifying and Servicing the C8 Corvette: Easier or Harder?
By -
C8 Corvette Engine Cover
C8 Corvette LT2 V8 will take nicely to upgrades, although most work will require lifting the car.
Two aspects of the Chevrolet Corvette which have contributed to its legendary popularity is the general ease of modification and maintenance. Compared to many other sports cars, it is easier and less expensive to upgrade the performance abilities of a Corvette. The past Chevy sports cars have been easier to work on than many other sports cars. That was with the engine mounted in front of the driver. Now that the engine of the Corvette has been moved behind the driver, many people wonder if that will change.
Will the C8 Corvette’s LT2 engine take to upgrades as well as the LT1 and other past high performance Chevrolet engines? Will the relocated engine be harder or more expensive to work on? Today, we look at those two questions based on what we have seen from the initial C8 owners.
Modifying the C8 Corvette
The LT2 engine in the C8 Corvette is based on the LT1. The key differences between the LT1 and LT2 are that the new engine has a larger intake manifold, a unique camshaft, exhaust manifolds that are routed up rather than down, a new front-drive belt system and a new oiling system. We know that the LT1 makes big power with forced induction or nitrous oxide, and we bet the LT2 will take to those upgrades even better.
C8 Corvette
The LT2 intake manifold’s higher volume will allow owners who are looking to add power to pack in more air more quickly, even without forced induction. The increased airflow coupled with more fuel will help the LT2 make more power, but with forced induction, we can expect to see the C8 engine making monster power.
It is likely to take a little while for the aftermarket to create some of the unique components to work with the mid-engine architecture. Once the top manufacturers get to making C8 performance parts, we are sure to see a huge aftermarket with lots of power-adding options. Aftermarket camshafts, exhaust systems, intake manifolds, and cylinder heads will all help add power without forced induction. However, it all begins with unlocking the LT2 engine computer.
LT2 Header
Unlocking the LT2
The engine computer of the C8 Corvette uses a new encryption system that is said to be the toughest the General Motors has ever used. When the computer is locked, tuners cannot adjust the engine parameters such as fuel flow or spark timing to make big power. For example, to get the most from an aftermarket supercharger system, you need to tune the engine computer, but right now, that is not possible with the LT2.
C8 Corvette Engine
We are sure aftermarket tuning companies are working to unlock the C8 Corvette computer system. Once the LT2 computer is unlocked, the real fun with the C8 will begin.
We have seen from the first examples of the C8 Corvette Stingray to be delivered that the LT2 engine computer will self-adjust for some considerable power additions. For example, Carlyle Racing was the first shop to put a C8 in the 10-second range with a nitrous oxide system. That run was made without a tune and without any trouble. Hennessey Performance has even added a twin-turbo setup with low boost levels on the stock, untuned engine computer. We don’t know how hard the injectors are working to feed the boosted LT2 without a tune. It appears as though the C8 will take a little nitrous or boost without a tune.
C8 Corvette LT2
That is good news for those owners who want a little extra power. For the big numbers, we need the aftermarket tuning companies to unlock the LT2 security system.
Working on the C8
Most of the work performed on the C8 engine will be done from underneath. It seems that there is no access panel in the passenger compartment. That won’t really matter for people buying the cars new and leaving them stock. If something goes wrong, they can take their new, stock cars to the dealership to be fixed under warranty.
However, there will be no warranty for secondary buyers. They will have to pay for service or fix things themselves. That could be costly or problematic if you don’t have a lift.
The C8 Corvette’s mid-engine design creates some problems for accessing the engine relative to a C7. Some things such as changing spark plugs, a serpentine belt or portions of the air intake system can easily be changed while standing around the front end of the C7. With the C8, it seems that accessing the top-front of the engine will be difficult-to-impossible from above. Much of the work will be done from below. The work won’t actually be more difficult, provided that you have a lift. Owners without lifts will be working on their backs much of the time.
And, for the serious upgrades, the engine will need to be dropped.
C8 Corvette
The top end of the LT2 may be accessible from the top. It seems like it would be easier to work on the engine if it were removed from the Corvette. Upgrades like a camshaft swap will definitely require the engine to be dropped. A cylinder head swap might also be hard to do with the engine in the car.
The good news is that adding a twin-turbo setup can be done from below. A simple bolt-up turbo kit can be installed with the engine in the car. You will still need the lift, but you won’t need to drop the engine to add impactful forced induction.
Photos: General Motors
Join the Corvette Forums now!
"Before I was old enough to walk, my dad was taking me to various types of racing events, from local drag racing to the Daytona 500," says Patrick Rall, a lifetime automotive expert, diehard Dodge fan, and respected auto journalist for over 10 years. "He owned a repair shop and had a variety of performance cars when I was young, but by the time I was 16, he was ready to build me my first drag car – a 1983 Dodge Mirada that ran low 12s. I spent 10 years traveling around the country, racing with my dad by my side. While we live in different areas of the country, my dad still drag races at 80 years old in the car that he built when I was 16 while I race other vehicles, including my 2017 Dodge Challenger SRT Hellcat and my 1972 Dodge Demon 340.
"Although I went to college for accounting, my time in my dad’s shop growing up allowed me the knowledge to spend time working as a mechanic before getting my accounting degree, at which point I worked in the office of a dealership group. While I was working in the accounting world, I continued racing and taking pictures of cars at the track. Over time, I began showing off those pictures online and that led to my writing.
"Ten years ago, I left the accounting world to become a full-time automotive writer and I am living proof that if you love what you do, you will never “work” a day in your life," adds Rall, who has clocked in time as an auto mechanic, longtime drag racer and now automotive journalist who contributes to nearly a dozen popular auto websites dedicated to fellow enthusiasts.
"I love covering the automotive industry and everything involved with the job. I was fortunate to turn my love of the automotive world into a hobby that led to an exciting career, with my past of working as a mechanic and as an accountant in the automotive world provides me with a unique perspective of the industry.
"My experience drag racing for more than 20 years coupled with a newfound interest in road racing over the past decade allows me to push performance cars to their limit, while my role as a horse stable manager gives me vast experience towing and hauling with all of the newest trucks on the market today.
"Being based on Detroit," says Rall, "I never miss the North American International Auto Show, the Woodward Dream Cruise and Roadkill Nights, along with spending plenty of time raising hell on Detroit's Woodward Avenue with the best muscle car crowd in the world.
Rall can be contacted at QuickMirada@Yahoo.com
