Sponsored by: Innova
rear speakers
Old Feb 9, 2005 | 05:16 PM
vetteboy88's Avatar
vetteboy88
Default rear speakers
First of all, it came out easy enough. How the hell do these boxes go back in????!!! There must be a neat little trick out there that someone knows of, one that will make me feel real stupid for asking this question!!!
Old Feb 9, 2005 | 08:53 PM
bogus's Avatar
bogus
huh... they should just drop back in.
Old Feb 9, 2005 | 11:20 PM
snoopdan's Avatar
snoopdan
uhmmm.. Bigger hammer?
snoopdan
Old Feb 10, 2005 | 05:13 PM
vetteboy88's Avatar
vetteboy88
Yeah, I had to walk away from it before the hammer came out.....I put the job away for another day. Thanks anyway!!!
Old Feb 10, 2005 | 07:43 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I have mine out right now for sub install. I will try and slip it back in and see if i have grief or there is any trick.
I will post my results soon
Old Feb 10, 2005 | 07:58 PM
AGENT 86's Avatar
AGENT 86
Well i have 3 questions ?
Are you trying to install through opening in carpet ? (should be behind carpet)
Do you have the correct bose box for the side you are trying ?
Did you pull the harness out of the way before install attempt ?
I ask these because i tried several times and had no real problem. I had more trouble getting it out, probably due to the fact i just pulled the carpet back to remove and install.
Old Feb 11, 2005 | 01:32 PM
vetteboy88's Avatar
vetteboy88
Yep, had the carpet pulled out because I'm replacing that also. I thought the boxes may have been mislabled left and right, but they are okay also. I haven't got back to it yet, and it's getting colder here in R.I. again, so that probably had something to do with it!!!!!! I will try again whenever this ?%^*&%#^%$% winter is over!!!!!!!! Thanks
To rear speakers
