Sponsored by: Innova
Accumat Or Dynamat
Old Mar 9, 2005 | 12:34 AM
T_Vert's Avatar
T_Vert
hey what is the diff between that ebay guys brown bread and extreme? One is $200 / 100 sqft vs. $100 / 100 sqft. do you think id notice a sound difference?
thanks
dave
Old Mar 9, 2005 | 04:43 AM
snoopdan's Avatar
snoopdan
Dont forget about eDead, which is the cheapest ive found so far, at 1.50 a square ft. I just ordered some...i'll see how it goes
snoopdan
Old Mar 9, 2005 | 08:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
thanks
dave
One is thicker than the other. I'm sure there would be a difference, how much, not sure.
Old Mar 9, 2005 | 09:19 AM
knewblewkorvette's Avatar
knewblewkorvette
here is a link to a comparison chart
http://www.b-quiet.com/compare.html
I just purchased 150 ft of B-Quiet Ultimate, 24 ft of Lcomp, and 54 ft of Vcomp. I will try and see if I can get two cars done with that but I think I will come up shy. I plan on doing both the inner and outer panels with the Ultimate and doubling up on the Vcomp where I can. The place I can't double up on the Vcomp I will use the Lcomp (better stuff but over twice the price ) My doors have been done already but will probably add more.
Old Mar 9, 2005 | 10:45 AM
T_Vert's Avatar
T_Vert
im just trying to figure out if its worth twice the price or not. Will 100 sq ft cover the entire car?
Dave
Old Mar 9, 2005 | 03:13 PM
AGENT 86's Avatar
AGENT 86
Dave
Old Mar 9, 2005 | 06:27 PM
T_Vert's Avatar
T_Vert
what do you guys have? The extreme or the cheaper stuff? Think the expensive stuff is worth twice as much? Would I be better off putting a layer of the FK down before this stuff or vice versa?
thanks!
Dave
Old Mar 9, 2005 | 08:00 PM
worldtraveler's Avatar
worldtraveler
From: Proud dad of 2 responsible adults and 1 fallen warrior txtx
Are there any odor issues with the materials containing asphalt products?
Old Mar 9, 2005 | 10:51 PM
snoopdan's Avatar
snoopdan
Im trying the ultra cheap alternative, after I read alot about the different types of insulation on car audio forums. I picked up 50ft of eDead 1.5 at 1.50 a foot, and a 20% discount on top of that if you are a registered Sounddomain user
We'll see how it goes. The damn shipping on any of this deadener material is horrible, no matter what you buy.
www.elementaldesigns.com
I'll try it out for the hell of it. If anything, it cant hurt.
snoopdan
Old Mar 10, 2005 | 12:07 AM
T_Vert's Avatar
T_Vert
how much was shipping? By Edead 1.5 do you mean the SE stuff? How did you apply the discount. That stuff is quite heavy compared to dynamat too a .5lb/ sq ft.
Dave
Old Mar 10, 2005 | 01:45 AM
Kale's Avatar
Kale
Forget frost king, period.'
The heavier the dampening material, the better it does. The idea is to add weight!
Also, I would call ED and ask if it is OK to apply their product to vertical surfaces.
I bought smoe Edead V.2, and the site made no mention that it wouldnt work on vertical surfaces, so I was stuck with it when it all failed. And according to them, I should have called, instead of expected it to work as well as every other dampener on the market.
Secondskinaudio has a new liquid dampener coming out. Stuff is supposedly like peanut butter, and it hardens. Supposedly, this is the best way to go. It is the way i plan on going.
Old Mar 10, 2005 | 02:09 AM
T_Vert's Avatar
T_Vert
Kale, how did it fail?
Dave
Old Mar 10, 2005 | 02:49 AM
  #33
Kale's Avatar
Kale
Sorry I should have been more specific.
The adhesive failed, and the stuff came off the panels.
Old Mar 10, 2005 | 10:59 AM
  #34
snoopdan's Avatar
snoopdan
Kale, did you clean the door panels first with acetone or some other solvent? I dont think I read specificallly where you had to do it, but I kinda thought it was a given for preping a door for some adhesive.
as far as shipping for eDead, its $19 for shipping for my 50 ft....to apply the sounddomain coupon, you have to look it up on their site, get the coupon code, then when you are about to finish your online order, it asks you for whatever coupon code you have, and subtracts the 20 percent.
snoopdan
Old Mar 10, 2005 | 01:20 PM
  #35
gpotski's Avatar
gpotski
I used Dynamat Extreme...and no odor at all.
It also sticks to vertical surfaces very well.
Old Mar 10, 2005 | 02:09 PM
  #36
T_Vert's Avatar
T_Vert
well i just bought 100 ft of the brownbread ultimate and some v comp to lay over it. Lets hope it works well!!
Dave
Old Mar 10, 2005 | 03:47 PM
  #37
Kale's Avatar
Kale
Yeah, I scrubbed those doors. they were brand new doors as well. I've put Stinger Roadkill on other doors before years before. No problem with those.
To Accumat Or Dynamat
Old Mar 10, 2005 | 05:25 PM
  #38
knewblewkorvette
Dave
Since you will more than likely get your applied before I do, fill me in on your results, pluses and minuses. It would be greatly apperciated. Thanks Jay
Old Mar 12, 2005 | 12:49 AM
  #39
T_Vert's Avatar
T_Vert
will do. Hope to have it done in a week or so. I really want to drive the car some more before i put it in. ANyone in the NW burbs of chicago wanna loan me a DB meter so i can get results??
Dave
Old Mar 12, 2005 | 08:14 AM
  #40
Kale's Avatar
Kale
You can get a fairly decent one from radio shack for $30- get the analog one. Its not pro grade, but is decent for comparing measurements.
