Sponsored by: Innova
Need amp advice
Old Apr 26, 2005 | 08:13 AM
Blown_Z06's Avatar
Blown_Z06
Default Need amp advice
I just got 2 10" MB Quart RWE 254 Reference Subs. they handle 300watts max i believe....what is a good amp to push them. I dont want to spend over $200-250.
Also, can i add tweeters to the stock bose headunit??
Old Apr 26, 2005 | 01:47 PM
scott_fx's Avatar
scott_fx
are they single voice coil or dual?
and are they 2 ohm or 4 ohm?
you can replace the stock 'twiddler' with aftermarket 3.5" speakers, that'll improve your highs.
Old Apr 26, 2005 | 01:50 PM
Blown_Z06's Avatar
Blown_Z06
Dual Voice Coil
Nominal Impedence: 2 x 2 / 2 x 4 Ohms
what is a twiddler?? lol i dont know much about component speakers
Old Apr 26, 2005 | 01:57 PM
scott_fx's Avatar
scott_fx
twiddler is the term 'we' use for the crappy bose speaker that isn't a tweeter, nor a mid range speaker. it's the 'other' speaker in the door.
hmm...the impedence that you listed seems like it's from the website :-) ... do you have the 2x2 or 2x4 version?
Old Apr 26, 2005 | 02:00 PM
scott_fx's Avatar
scott_fx
also... are you looking for new amps or would used ones be up your alley too?
Old Apr 26, 2005 | 07:07 PM
Blown_Z06's Avatar
Blown_Z06
used is fine....i have the 4 ohm version.
Old Apr 26, 2005 | 11:57 PM
scott_fx's Avatar
scott_fx
ok so if you have 2 (2x4) subs with rec. wattage raiting of 300 watts rms each.
That means you can either get a:
-mono amp that can run ~600 watts @ 4 ohms... i think this maybe expensive for a quality amp
-a 2 chan amp that is stable at 2 ohm and can run close to ~300 watts a chan.
-or get a 4 chan amp that can handle 2 ohms when bridged... this will be rare in an amp in that price range
I would recommend looking for a used jl audio, a phoenix gold, or xtant.
I would actually try to exchange them for the 2x2ohms. that way you can get a mono amp that can handle two ohms easily?
Old Apr 27, 2005 | 08:14 PM
scott_fx's Avatar
scott_fx
http://cgi.ebay.com/ws/eBayISAPI.dll...770244714&rd=1
Old Apr 27, 2005 | 08:51 PM
scott_fx's Avatar
scott_fx
http://cgi.ebay.com/ws/eBayISAPI.dll...770285868&rd=1
To Need amp advice
