Sponsored by: Innova
In Dash CD Problem
Old Jul 5, 2005 | 02:37 PM
Cherry2000's Avatar
Cherry2000
Default In Dash CD Problem
My in dash CD player has stopped working. I get a readout of Err when I try to play a CD now. Has this happened to anyone else? Is there a quick fix I should try before going back to the dealer? Any advice would be appreciated. The car is 2000 TR Coupe 6sp w/18k miles.
Old Jul 6, 2005 | 05:46 AM
JimNY's Avatar
JimNY
It could be a number of things. If your player is loading the disk perhaps you have a bad CD or a dirty lens or the player. I'd try a few different disks first, then a lens cleaner.
I wouldn't go back to the dealer for this unless you're covered under an extended waranty. If the CD player is fried it's pretty easy to swap it out.
Old Jul 6, 2005 | 10:40 AM
Cherry2000's Avatar
Cherry2000
Thanks JimNy....I guess my next step will be to try a lens cleaner. I've looked at replacements at Corvette Radio and other websites and it looks as if that will run me from $300 - $450, depending upon where you get it. For that type money it may be a better option to look at something different. In reading a lot of posts about the Bose system I don't get the warm and fuzzies. Maybe someone can give me a class act stereo installer's number in the Atlanta area.
Old Jul 7, 2005 | 11:16 AM
Cherry2000's Avatar
Cherry2000
Well, the lens cleaner did not work...the CD player just spit it out also and gave me the Err message. I guess it is toast. I've gotten several good ideas by reading completely through this forum and will probably seek out an installer for a new system. Thanks for the replies here and in the tech area where I originally posted by mistake.
To In Dash CD Problem
