Sponsored by: Innova
Subwoofer Help
Old Aug 30, 2005 | 01:23 PM
JoeZ's Avatar
JoeZ
Default Subwoofer Help
I bought an Alpine M350 amp with a 12" Alpine type R sub and have it installed in my car. It works properly and all, but it seems to need adjusting or something, because the sub won't go very loud before bottoming out or getting distortion or what ever it is doing. It just souds like crap at higher levels.
I've had cheaper equipment that sounded better before this, I don't understand what I need to do to clean it up.
Help please!
Old Aug 30, 2005 | 02:27 PM
EatRice's Avatar
EatRice
It could be the xover and/or the gain. It could be the enclosure is the wrong size or it could be how you have interfaced with the stock radio. How is it interfaced?
Old Aug 30, 2005 | 03:11 PM
RFDrpm's Avatar
RFDrpm
Hey ive got the same amp with a sws 12 and never bottom out.
1. turn the gain to half
2. Turn the bass boost to 0 ( its the one in the middle)
3. Play with you crossover frequency till you get the sound you want.
4. SLOWLY bring you gain up, youll probally get to full power before you max that sub.
5. Now bring the bass boost up, once you hear it drop bottom, bring it back down a hair.
6. There you now have dialed in your amp and speaker....
What kind of deck are you running, do you have sub output control?
Old Aug 30, 2005 | 04:15 PM
knewblewkorvette's Avatar
knewblewkorvette
his discription leans me towards an incorrectly built box
Old Aug 30, 2005 | 04:21 PM
RFDrpm's Avatar
RFDrpm
That could be the case, but with the bass frequecny boost on that amp it is easy to overload the speaker...
So, it the box ported or sealed. Box volume should be 1.25 cu ft sealed or 2.0 cu ft ported.
Old Aug 30, 2005 | 06:18 PM
knewblewkorvette
the reason I say a leaking box (or incorrect box) is his statement "because the sub won't go very loud"
Old Aug 30, 2005 | 06:47 PM
bogus's Avatar
bogus
Was this attached to a bose based system? Were any adaptors used? Were they needed?
Old Aug 30, 2005 | 08:36 PM
EatRice's Avatar
EatRice
I just realized you are in Tampa...shoot me a PM. I will look at it for you.
Old Aug 31, 2005 | 08:21 AM
JoeZ's Avatar
JoeZ
The box should be fine...it was used on another 12" sub setup that my buddy had and he was pushing serious power with great results.
I have it hooked up to my stock bose and I tapped the preouts in the back of the hu.
I think it is improperly adjusted because i do have the bass gain up what seems high after reading how you guys said to adjust it. I'll try to set it then get back to you all.
THANKS!
Old Aug 31, 2005 | 08:45 AM
EatRice's Avatar
EatRice
Did you use an adaptor to tape the perouts on the head unit?
To Subwoofer Help
