Sponsored by: Innova
It worked!
Old Feb 9, 2006 | 11:23 PM
ROD BROWN's Avatar
ROD BROWN
Default It worked!
I am sure most of you fellows are going to laugh at what you read,but here goes,I installed a Roady 2 in my 99 and the reception was terrible.Static,lost reception when I went under an overpass.Don't even think about a tunnel.Well,I had the home kit and I replaced the small auto antenna for the home antenna and wow,no more losing the signal,no more static.I thought I would share this small bit of info with the forum "brothers" that may have the home kit laying around not being used.I installed the antenna in the large middle compartment where the spare tire would normally be.When it comes to doing anything to do with electronics,I am the worlds best candidate for clutz of the year.
Old Feb 9, 2006 | 11:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ok i think you had recepention problems cause the antenna should be on the outside
Old Feb 10, 2006 | 03:49 AM
scott_fx's Avatar
scott_fx
still impressive that the other antenna picks up so well.
To It worked!
