Sponsored by: Innova
A little help please...........
Old Mar 17, 2006 | 11:12 PM
fej's Avatar
fej
I have mine behind a partition and it certainly muffles the sound some but a bit more gain and tuning and it is not really noticeable
Fej
Old Mar 18, 2006 | 08:35 AM
Laguna Blu's Avatar
Laguna Blu
Fej
Good to know. Any particular brand of AMP that I should avoid? Seems I'm satisfied with a 24DAC head unit by Eclipse or Pioneer or maybe even Alpine with front speakers by Focal. The brand of sub-woofer and amp are up in the air. Also I'm not sure if I need a separate amp to run the door speakers and the rear woofer or one amp would be sufficient?
Old Mar 18, 2006 | 06:44 PM
fej's Avatar
fej
Much like anything you get what you pay for. If you spend $120 on a 4 channel 75x4 amp you would be lucky to see 30x4 clean watts. On the other hand if you spend $500 on the same specs you would likely see 75x4 or maybe even 82-88 watts x4. Most higher end better quality amps come with a birth sheet that lists the actual tested watt total per channel.
I try not to name brands to stay away from, but if you can buy them at an Automotive store (kragen etc) a Walmart, or similar volume retailer I would stay away. Your money can be better spent.
Xtant, ARC Audio, Mcintosh, Brax, Tru, DLS, Genesis, Diamond Audio, JL Audio all make very well respected quality amps.
Fej
Old Mar 18, 2006 | 07:01 PM
scott_fx's Avatar
scott_fx
if your installer has phoenix gold, check out the pg 500.4ti I had one in my car (now its sitting in my room because i can't let it go) and i was extreamly happy with it.
