A little help please...........
http://forums.corvetteforum.com/show...2&forum_id=103
How many amps? How many subs? What music do you listen to? How much room are you willing to give up on the interior of the vehicle?
As I mentioned I like your front speaker choice a lot. I would give up the rear speakers altogether. A nice front stage set up like you have will easily fill a vette interior with sound.
Help us help you bro
Fej
anyways.... let us know what brand names the choosen installer carries and then we can all give you input. are you looking for navigation/lcd screen type of head unit?
Anyhow, I read your entire other thread. Good choice on the Focals for the fronts. I agree with Scott on no rears. JL Audio makes a great amp (can be ordered in chrome for flash effect
) Many on this site have gone with the double Din Pioneer Nav units.Best wishes
Fej
As for the amps JL makes a nice amp as does Zapco, ARC audio, and my personal amp which I am really happy with is the Genesis line made in England. I have the Profile line which is their lower end amp in a 5 channel that runs my entire system. I have it installed underneath my non power passenger seat and it pushes my 3 way front stage (mainly Focal) and my Image Dynamics IDQ 12" sub with the gains all at minimum and my Eclipse headunit at 70/80 as loud as you would want to hear any music
At the end of the day, when you buy an amp you are paying for THD (total harmonic distortion, lower the better) and advertised, or hopefully better than advertised RMS watts. Example would be a 4 channel 50 watt per channel amp (50x4). You could buy one of these amps for $150. And it would likely put out 30x4. You could also buy one for $500. And that amp would likely put out 57-65x4.
Many people build an amp rack behind the seats on that rear shelf and set up all of their components there. Check out the install thread in the audio forums here.
As for a Headunit I would recommend the Eclipse line. The Pioneer line is very nice and popular here with the Vette folks for the Navigation option as well. The new Alpine line has started getting some pretty decent reviews as well. Stay away from the "glidetouch" IMO. I personally have the 8053 eclipse with built in crossover functions and EQ as well as a 24bit DAC (just think slightly better reading of the CD for better accuracy over a 1bit DAC)
Hope this helps some.
Fej
pioneer: gps unit that also plays music
eclipse: high end head unit that also has gps.
make sense? you can see where each companies priorities are. doesnt mean that either one of them is a bad product but more what they are focusing on.
i have sacraficed very little trunk space with my install. mount your amp(s) behind the waterfall, right below where the top folds down (not very usable space anyways) and get a subthump box with a decent sub (i went with an idq12 and am very happy with it)
for amps. in a vert with mods like ours get as close to or above 75 watts for the door speakers. 300+ watts for the sub and you should be happy. along with the brands recommended above also check out audison and xtant. I have an xtant and it's the best am *I've* ever owned (my past amps have been ppi, eclipse, phoenix gold (ti series), as well as a kenwood when i was in highschool
for amps selections, maybe ed amps:
http://edesignaudio.com/category.php?type=amps
nine.4 for the front speakers (bridged)
and nine.2 for the sub. (get a 4 ohm sub or dual voice coil 2 ohm sub) or if you're going to get a beefier sub go with the nine.1 and we'll have to figure out the impedance of the voice coils (measured in ohms like above) based on the power requirements of the sub
oh...and you dont need two amps you can just use one if you rather. you wont get as much power but you could be happy as well. my xtant is a 3 chan amp that will power the front speakers with 75 wrms (watts rms) and the sub with about 300 wrms.
you dont need the custom vrumvrum faceplate it's more of an asthetic thing. I think the vrum vrum kit makes a single din unit look great in the factory location, if you're already investing that much into the system i think it's a nice finishing touch.
let us know as you start picking components and we'll help you narrow down what else you need. the sub will seem tricky with all the different impedances, but it's pretty straight forward when you're familiar with it. we can help you with that when the time comes.
Yes, the sub goes in the rear. Since it willl only play low frequencies it does no screw up the front stage.
Got ya. No rear speakers but do the Woofer in the box out back.
Also heard good things about McIntosh @ Nagamichi products.....pricey though.
mcintosh and nagamichi
http://cgi.ebay.com/ebaymotors/2-Pha...spagenameZWDVW
get these!!!!
i'm tempted to even get these for myself!
get these!!!!
My current set up is:12" sub 63hz and down (18db)
7" midbass 63hz to 400hz (24db)
3" mid 400hz to 3.5k (24db/12db)
1.1" tweet 3.5k up (12db)
Certain songs will have the bass bounce around a bit between front and rear but not so much that it bugs me (yet
) With your proposed set up you really will NEED good quality sound deadening in the doors in order to support some nice upper sub to midbass frequencies up in your front midbass speaker. The crossovers on the Utopia line I believe are 18db. I think the Polykevlar are still 12db.Fej
get these!!!!
