Sponsored by: Innova
6" linear movement
Old Jun 28, 2006 | 09:49 PM
scott_fx's Avatar
scott_fx
Default 6" linear movement
Hey guys,
need some help here. I need to automate a (light weight) panel to move about 6" back and forth. I'm guessing my best choice would be to get a linear actuator, but at $100 it's kind of a steep investment. What other options do i have for reliable repeatable automations?
I was thinking lead screws but by the time i get everything i need it's going to be close to the linear actuator's cost but not be as sturdy.
then i thought about getting smooth gliding track and a motor/wheel assembly with electronic switches at the beginning and end of travel.
any ideas? thoughts? suggestions?
thanks
scott
Old Jun 29, 2006 | 06:36 AM
DiverDown's Avatar
DiverDown
It depends on what you are trying to accomplish and how. It could be done with just a simple dc motor, limit switches, a shaft and a couple of linear bearings.
But again it depends on what you are trying to move, how smoothly and accuratly, and the space and power requirements.
Old Jun 29, 2006 | 10:39 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
We have used power seat motors before from old cars
Old Jun 29, 2006 | 02:28 PM
scott_fx's Avatar
scott_fx
i just got a cheap scanner off of ebay. it is usb powered (aka 5 volts) and has the track and motor and everything. I think this is a good option for my setup, we'll see
Old Jun 29, 2006 | 05:32 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
whats the project you are planning for it?
Old Jun 29, 2006 | 05:37 PM
scott_fx's Avatar
scott_fx
it's for my car pc
Old Jun 29, 2006 | 09:03 PM
Team DCA's Avatar
Team DCA
If you haven't already, check out Select Products. They have the actuators and sliding tracks of all kinds for automotive installations along with a bunch of other neat stuff.
Old Jun 29, 2006 | 09:09 PM
scott_fx's Avatar
scott_fx
thanks, thats the first place i look for product info, then i go and find stuff a lot cheaper else where :-) but i think the scanner mechanism will do exactly what i want with little modification.
Old Jul 3, 2006 | 06:16 AM
CorvetteSteve's Avatar
CorvetteSteve
Looking forward to any pictures you might post of the new project.
Old Jul 3, 2006 | 06:22 PM
Audio Dave's Avatar
0Audio Dave
Former Vendor
From: Murfreesboro, TN. "I'm like a kid in a candy store everytime I see a Corvette!!"
In car audio installations that are lightweight, a simple trick is to use a power antenna, cut to the length you need, attached to the unit you are trying to push out (like a small amp drawer or electronics, etc.), and use some drawer slides from your local home improvement store for the rack to slide on. Works great, but again only for lightweight applications, and those that are pushing and pulling out, not really for pushing up.
Hope this helps!!
To 6" linear movement
