Sponsored by: Innova
My C4 installation
Old Jul 15, 2006 | 06:09 PM
ToniH's Avatar
ToniH
Default My C4 installation
Hi, I am in the middle of audio system installation in my '90 Coupe.
8" subs to rear speaker boxes and an amp for them are already installed. I believe I managed to make the rear boxes airtight. Also power from battery + ground wires and rear speaker wires are in place.
Tomorrow I will be start hu and front speaker installation. We have already figured out the necessary wiring for battery, ignition, ground, illumination and antenna in my cars wire harnesses. So I don't expect problems in that area.
I will install all new speaker wiring, none of the cars will be used. Front speaker boxes will be fabricated by myself. Today I recovered the front speaker covers and hope to be able to use them with the new boxes.
I noticed that my new head unit (Blaupunkt Las Vegas DVD35) has very thick face plate. It must be twice the thickness of my old Pioneer. I am afraid that this will cause it to stick out from the center console and it will look silly.
My question is: I am sure others have also seen this problem but is there a good way to solve it? Grind the plastic rear wall inside the dash and somehow install the hu deeper?
Here is some installation pics of what has already been done:
Subs and the amp
MDF plates
Finished installation plates
Sub in place and wired
With carpet
Stock speaker cover over the 8" sub
amp installation plate
Test fitting the amp
Amp installed on the passenger side, under seat
Old Jul 16, 2006 | 04:27 PM
scott_fx's Avatar
scott_fx
looks like you are well on your way. looking good too. sorry i cant help you with your problem but I'm sure someone can give you an answer...which is probably 'you're s.o.l.'
keep up the good work
Old Jul 16, 2006 | 06:56 PM
wiz1500's Avatar
wiz1500
Very nice... ......I love the steath of it all.......keep it low profile and let it rock...As for your ? I have not ever ben there so I can't help with your fix..I can say that if you put the right plate up there you may be ok with it sticking out.
Old Jul 16, 2006 | 07:12 PM
RFDrpm's Avatar
RFDrpm
I got rid of the plastic piece in the back of the dash w/a 3/4" drill bit. Just went to town on it. It was keeping my wires from going back in the dash. Give it HELL....
Old Jul 17, 2006 | 03:32 PM
ToniH's Avatar
ToniH
On sunday we finally installed rest of the audio system. The whole day was plagued with little difficulties but in the end we were succesful and by 11 PM music was playing in my Vette after 6 musicless years!
We also grinded some of the backwall off to make the wiring fit better.
After some experinmenting with hu EQ settings and sub amplifier settings the system now sounds very nice.
Hmmm...the face plate on the Blaupunkt hu is so thick it will stick out!
All wiring ready and the crossovers seem to fit under the hu
Power connection done!
Speakers starting to fit too
Hey, it works!
Hu looks pretty good in there
Old Jul 17, 2006 | 05:27 PM
DPG's Avatar
DPG
St. Jude Donor '06
its looking great
To My C4 installation
