Sponsored by: Innova
Delco Bose Question
Old Jul 28, 2006 | 10:11 AM
tramlaw33's Avatar
tramlaw33
2nd Gear
Default Delco Bose Question
I just got a new stereo for my 86 convertible, it used to have a delco bose stereo in it, but it's shot. The wiring doesn't match up easily from the new stereo, which obviously isn't an original bose. My question is, where can I get a wiring harness to hook up the new stereo? It sure would make it a lot easier to hook everything up. Thanks in advance.
Old Jul 28, 2006 | 10:13 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I'm not sure about this (others will chime in though) but I believe you have to change the speakers, or modify them, as well. The Bose sytem amplifiers are in each speaker, not the head unit.
Old Jul 28, 2006 | 10:40 AM
tramlaw33's Avatar
tramlaw33
2nd Gear
Default Re:
You are correct, the amplifiers are in each speaker. Someone told me I wouldn't have to change each speaker, which I hope is the case. The power supply to each amp is connected with the positive and negative for each speaker, and the guy I talked to said if I get a harness, it would include the power to the amp as well. Anyone know?
Old Jul 28, 2006 | 03:52 PM
1986coupe's Avatar
1986coupe
You can normally find a wiring harness at auto parts stores which will connect an aftermarket deck to the original GM wiring. Trust me, don't cut wires...buy the harness. I put a bose back into mine because a previous owner did a terrible wiring job. It has been difficult.
As everyone has pointed out, you will have to purchase different speakers. The Delco Bose speakers have the amps built into the enclosure. With aftermarket speakers you will certainly get more bass.
Old Jul 28, 2006 | 03:58 PM
topgunvette's Avatar
topgunvette
Old Jul 28, 2006 | 04:28 PM
C4boy's Avatar
C4boy
You can get a wiring harness adapter almost anyplace that sells car stereos. Walmart, Circuit City, Best Buy, Autozone, local car stereo installers. Depending on your new deck, you can probably use the RCA outputs with some line level adapters and maintain your Bose speakers. I think there's info in the car stereo forum on how to do this. Any decent installer/local car stereo place should be able to get you the right parts easily.
Old Jul 28, 2006 | 05:22 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Ecklers and other Corvette suppliers sell adapters that allow you to retrofit your Bose speakers to use with most new stereo systems.
Old Jul 28, 2006 | 06:13 PM
topgunvette
what are the specs on the amps that power the stock speakers?
Old Jul 28, 2006 | 06:50 PM
bogus's Avatar
bogus
this is the exact type of thread that belongs in the audio section.
Forums ==> General Corvette ==> Audio/Electronics.
Also, there is a C4 Audio FAQ that will explain a lot.
To Delco Bose Question
