Sponsored by: Innova
complete bose overhaul - HELP!!!!
Old Aug 12, 2006 | 09:42 PM
SpeedCoach's Avatar
SpeedCoach
Default complete bose overhaul - HELP!!!!
howdy folks -
my dad is tired of the BOSE system in his 1991 vert. what we really want to do is completely update the system - new speakers (w/out! the individual amps), new head unit, the whole nine. at present we have removed the head unit, the tuner unit (from behind the glove box, the dash is off, etc.....
i've done several searches on the subject but the info seems sketchy at best....perhaps i'm not searching correctly...
has anyone done a complete update of the bose system? can anyone point me/us to any threads, sites, info on doing such a thing.....we're not really that worried about taking the whole thing apart to rewire, just looking for a bit of direction.
thanks guys!
Old Aug 12, 2006 | 10:29 PM
techguy's Avatar
techguy
If interested ... Ive done ALOT of Vettes -- just completed a '76
Let me know
soundzplus@aol.com
Warrenville,IL
Old Aug 13, 2006 | 10:56 AM
DPG's Avatar
DPG
St. Jude Donor '06
bogus is very knowledgable with the c4's he is not local but he has a ton of info about the c4 in his noggin
Old Aug 13, 2006 | 11:01 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
Im in the northwest suburbs of chicago if that is close to you and id be more then willing to help you out or do it for you. let me kno id be more then willing to make some suggestions for you or do an install for you
Old Aug 13, 2006 | 11:16 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Default Read the C4 FAQ
There is a Ton of info there...
Check back in if you have specifc questions; you can do it yourself with the info in the FAQ section. As stated above Andy Bogus knows a lot about this stuff; He helped me by answering the questions that I had when I did mine-great guy.
Good luck, Randy
Old Aug 14, 2006 | 01:11 AM
SpeedCoach's Avatar
SpeedCoach
Thanks for the offers, guys...
the car isn't with me in frankfort....it's at my fathers, a bit of a ways a away...
we charged ahead anyway, and here's what we have....
new stereo is "installed" (for the moment) - ran new speakers wire, made some baffles, etc (i left the pictures there - doh!).
new stuff works and sounds good, but.......
the only problem is the power antenna - it won't go up or down. we've boogered around a bit and figured out where the relays, etc were....if we ran a wire (obviously just for testing purposes ) - straight off the battery and into the orange wire on the relay located behind the driver, all the way in the back corner - with this temp wire in place the antenna worked normally, and the dome lights came back (which we didn't notice werent working until this made them work???? ). the only thing i can think is that the motor for the antenna is not getting constant power - which it obviously needs to make the antenna go down after the ignition is turned off. there is a "constant" wire that is hot within the dash on one of the harnesses that used to plug into the head unit - and the only thing that makes sense to me is that this wire's juice needs to get back to that relay somehow....
any suggestions from here - it's late, and i'm trying to be as specific as possible.
thanks again
Old Aug 15, 2006 | 11:36 AM
SpeedCoach's Avatar
SpeedCoach
bump
Old Aug 15, 2006 | 04:19 PM
DPG's Avatar
DPG
St. Jude Donor '06
thats sounds about right. you need that constant power for the relay. im pretty sure it doesnt matter where it comes from as long as its constant. Did you check the relay to see if its getting a constant power?
Old Aug 15, 2006 | 06:17 PM
SpeedCoach's Avatar
SpeedCoach
no, it's not getting a constant source of power....when we boogered some juice to it, however, everything worked as it should....does anyone know where the constant power wire for that relay originates?
Old Aug 16, 2006 | 01:10 AM
SpeedCoach's Avatar
SpeedCoach
Default Got It!!
heh....a fuze had blown and we missed it ....everything is good as new now.
thanks to those who offered assistance and knowledge.
To complete bose overhaul - HELP!!!!
