Sponsored by: Innova
Cd Player
Old Aug 31, 2006 | 01:16 PM
DBFCO2's Avatar
DBFCO2
Default Cd Player
I have 2003 stock radio w/cd player. If I pick up oem 12 disk changer w/wiring will this plug directly in my stock radio or do I have do addition wiring?
Old Aug 31, 2006 | 01:52 PM
muncie21's Avatar
muncie21
Check to see if you have the factory harness in the cargo area. If you do, it's a simple plug and play (no pun intended) endeavor.
Old Aug 31, 2006 | 01:58 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yep....if not its about $80-90
DBFCO2's Avatar
DBFCO2
I just looked, I did not see any wiring unless it is tucked under the stock carpet
Old Aug 31, 2006 | 02:00 PM
DBFCO2's Avatar
DBFCO2
Is this for the wiring I will need to plug directy into the stock radio?
Old Aug 31, 2006 | 02:10 PM
muncie21's Avatar
muncie21
The PN for the CD changer cable kit is: 12491182
It plugs in the back of the stock HU, runs to the back of the car and plugs into the stock CD changer.
Double check under your carpeting for the wiring. Lots of cars came factory with it.
Old Aug 31, 2006 | 03:13 PM
DPG's Avatar
DPG
St. Jude Donor '06
yup lots of cars came with it factory, then when sold the owner would see the changer for a quick buck. you should be able to pull the cargo net nuts and pull the end piece of carpet out to sneak a peek there. UNless the c5 coupe has different carpet than the frc's/
To Cd Player
