Sponsored by: Innova
VSS wire
Old Oct 29, 2006 | 08:48 AM
Mr. Blue's Avatar
Mr. Blue
Default VSS wire
I was told that there is a green/white VSS wire on one of the C5radio plugs if the radio has speed compensated volume. Seems to make sense. Can somebody verify this and tell me what the location is. From what I've read here, most folks pick this feed up from either the PCM under the battery or from the instument cluster. I checked the plug pinouts here on the forum and couldn't find it.
Old Oct 29, 2006 | 09:13 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
http://forums.corvetteforum.com/show....php?t=1535219
Old Oct 29, 2006 | 12:36 PM
Mr. Blue's Avatar
Mr. Blue
This is the guy (ironhead) that told me about the wire on the radio harness. He was told by someone that the wire is available on one of the plugs in back of the speed compensated Bose. Just trying to confirm that, since nobody else seems to use it and that would seem to be the easiest place to get to it.
To get to the VSS wire on the IP cluster plug, does the cluster have to be pulled, or can the plug be reached from underneath?
Old Oct 29, 2006 | 05:08 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
I dont remeber what color it is but the wire is deffinetly at the back of the radio
Old Oct 29, 2006 | 11:32 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
It would have to, otherwise how would it get the signal for the SCV
(Speed Compensated Volume).
To VSS wire
