Sponsored by: Innova
speaker size question
Old Nov 2, 2006 | 05:04 PM
scofolo's Avatar
scofolo
Default speaker size question
From the C5 FAQ:
What Size speakers will fit in the rear location?
You can fit 5.25” speakers in the rear of the c5 frc or vert and 6.5" for the coupe.
I have a coupe. Does this mean that 6.5" speakers will drop in without any modifications, or does it just mean that the area is big enough to fit 6.5" speakers but needs to be modified? Thanks.
Old Nov 2, 2006 | 05:20 PM
markcz's Avatar
markcz
Any standard 6.5" speaker will fit just fine without being modified. You can even do it without removing the trim. Start at the top of the grill and push straight down and slightly pull out at the same time. This will release the top tab, then just lift it up and out. However, don't try this with the front grills, it won't be pretty.
Old Nov 2, 2006 | 06:32 PM
leolufse's Avatar
leolufse
What he said. 6.5" will drop right into the REAR locations.
To speaker size question
