Sponsored by: Innova
[C4] System started
Old Dec 17, 2006 | 04:55 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default [C4] System started (Pics add 12-23)
I will plan on updating this thread going forward with pictures of the install..
here is what I have finished so far.. LOL
More pictures HERE
The back wall was the old piece that had my dual Orion HCCAs on it.. I will either remove the carpet if I can and re cover it, or build a new plate.
Getting there slowly..
Still debating on the 3-way vs 2-way for the front stage.. I could do either, we will see when I get that far
Old Dec 18, 2006 | 01:26 AM
bogus's Avatar
bogus
wow! moving along!!!
Old Dec 18, 2006 | 10:37 AM
Kale's Avatar
Kale
Great work so far! I"m looking forward to seeing the finished product.
Old Dec 18, 2006 | 01:56 PM
DPG's Avatar
DPG
St. Jude Donor '06
Old Dec 18, 2006 | 02:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
thanks guys.. there is not much there yet though...
Old Dec 18, 2006 | 10:19 PM
-=Jeff=-'s Avatar
-=Jeff=-
So my CDT EF-61 were delayed ( I got the ematl the day after I bought them) anyway I emailed the place today to check status as they said they would ship today. Well they never got more B stock sets in so I am getting the A stock set!!
Now I might upgrade to the Satnet 560 xovers and just run a 2-way system.. not completely sure yet although I still might run the 3-way..
Old Dec 18, 2006 | 11:09 PM
scott_fx's Avatar
scott_fx
very cool.... why aren't you mounting htose amps the long way? have something planned for the middle?
Old Dec 19, 2006 | 07:27 AM
-=Jeff=-'s Avatar
-=Jeff=-
Originally Posted by scott_fx
very cool.... why aren't you mounting those amps the long way? have something planned for the middle?
Nothing planned for the middle exactly, it was more if i ever wanted to swap the NINe.2 for another NINe.2x or NINe.1. Length wise will be very tight.. the NINe.2 is 12in long and the NINe.2x is 14.75in the width of the back area is 32in. so even 27in of amps is tight (plus room for cables and such. I also felt accessing the Gains and control might be a bit harder. the way they are installed will allow for easier access to the gains and RCAs if needed as that end will not be boxed off underneath.
It is also different from the ordinary
Old Dec 20, 2006 | 07:29 PM
-=Jeff=-'s Avatar
-=Jeff=-
no new pictures, I got my V4 eDead and need to install some of it
I also got my EF-61 today.. brand new perfect speakers.. impressive build quality for the woofers..
Looking forward to installing them
Old Dec 21, 2006 | 01:37 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Another update
Sold my NINe.2
Bought another NINe.2x
this car is going to either rock, or shake apart.. LOL
Old Dec 21, 2006 | 07:22 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
WOOT WOOT new toys for xmas
Old Dec 22, 2006 | 12:34 AM
Duramax Dave's Avatar
Duramax Dave
And I got myself the first part of the Chevelle stereo
Now I gotta get a NINe.1 to power the subs
Old Dec 22, 2006 | 07:24 AM
-=Jeff=-'s Avatar
-=Jeff=-
Technically the second part since you are using the eDi6500s from your truck
Old Dec 22, 2006 | 05:50 PM
Duramax Dave
Jeff.... you are correct! I'm excited for spring now...so I can get working on the car. But first is finishing the remodel jobs in my house....
Old Dec 22, 2006 | 10:05 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default eDead V4.. NICE stuff
So, I put some of the eDead V4 in today, got most the cargo area. (Pictures will follow).. I went out in the garage tonight to reinstall my cargo shade/cover, got that done and then I decided to try the V4, well I have one layer in the car, it is installed over the Raamat I had installed 2 years ago. I am thinking that the one layer of the V4 will replace the OEM green yarn looking stuff. Talking with Chris at eD he said the V4 is probably much better then the OEM stuff even at 1/2 the thickness.
Besides that I will have my amp rack over most of it and the carpet seems to fit a bit better.
I also got my 2nd NINe.2x today too..
Old Dec 23, 2006 | 05:41 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default COOL New Pictures
here are some updates:
V4 on back floor and wall:
Base of Amp rack carpeted and amps installed:
the carpet was a bit short on the outside but it will not be seen. I still have to trim some carpet a bit and add more pieces but it is getting somewhere..
rest of the pictures HERE
Old Dec 24, 2006 | 02:17 AM
pentavolvo's Avatar
pentavolvo
sweetness its lookin good
To [C4] System started
Old Dec 26, 2006 | 03:35 PM
-=Jeff=-'s Avatar
-=Jeff=-
Hoping to get the rest of the amp rack done this week (with exception of the top).. Still need to figure out what to do for the top.
I am also hoping to get the Storage compartments mounted as well. then I can slowly move to the front of the car.
Old Dec 26, 2006 | 03:38 PM
pentavolvo's Avatar
pentavolvo
ok Jeff can u carpet an enclosure cause i have carpet and i need to do my dual 15s box and my skills are bad after i did my HT box i cant do sides for jack and i dont wanna mess up the box for the big boys
Old Dec 26, 2006 | 04:04 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yeah I have done my fair share that have turned out real nice.. What type of backing is on it? we should be able to get it looking good..
