Sponsored by: Innova
Help with Ignition source?
Old Feb 10, 2007 | 09:08 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
Default Help with Ignition source?
I am in the middle of installing an aftermarket HU in my 2000 FRC. I connected the red wire from the HU to the yellow wire in the passenger footwell per C5 faqs but there is no power with or without ignition. Just tested the yellow wire and it is dead. Is there another ignition source around the footwell I can use?
Old Feb 10, 2007 | 09:36 PM
bogus's Avatar
bogus
have you checked the fuses?
Old Feb 10, 2007 | 09:46 PM
LS1 REDBIRD
Yes, I forgot to mention that I checked all the fuses after I tested the yellow wire.
Old Feb 11, 2007 | 02:08 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
that really weird that the yellow wire is dead you should be able to get a fuse tap and tap into i believe fuse 22 its listed in the faq
Old Feb 14, 2007 | 04:23 AM
markcz's Avatar
markcz
The yellow wire is supplied by fuse #11 in the passenger footwell. Did you check the right one?
To Help with Ignition source?
