Sponsored by: Innova
IPOD2CAR problem
Old Feb 19, 2007 | 01:27 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by DPG
oh man, sorry i missed this post. It is a fairly easily install if they can send you the right parts. and it is pretty damn confusing as to what you need to order. When you recieve your parts and are still having trouble, please let us know. Ill keep an eye out for this thread. Also, If I understand correctly, when you pulled the changer, you pulled the wirign for it as well? up to the pass footwell? Or is the cd changer cable still there in the trunk area?
I cut the wire and left it all in place. As for the right parts? I have the harness I need coming, should be here within the next couple of days. I will let everything know what comes of all of this.
Micah
Old Feb 21, 2007 | 07:00 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Originally Posted by pentavolvo
http://www.crutchfield.com/S-Tuvi5nU...arch=541GMH20T does appear to be the right cable... they may have changed model numbers which is why the other one shows as not in stock
Well, here is the update, I bought the cable above from cardomain.com for $9.95 and installed it tonight. It worked perfectly and now I have a big on face! It is clear as a bell and I can function the ipod through my headunit, so all is good.
If you have any questions, let me know.
Thanks to all that have helped out.
Micah
Old Feb 21, 2007 | 07:13 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
glad you got it workin, and 10 bucks at cardomain is a good price
Old Feb 21, 2007 | 07:56 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
Any pics or install details? My cable is due tomorrow. Sounds like it would have been cheaper and faster from cardomain.com.
Old Feb 21, 2007 | 09:06 PM
UTVOL06's Avatar
UTVOL06
guys go check out the USA Spec PA11-Vette adapter for the Corvette. it hooks into the rear trunk area where the 6-disc cd changer would go. You have to have XM radio or buy an optional cord if you don't. Either way no subscription to XM is required. Its a direct digital connection.
I just bought one today after reading a few others that use it or the gm approved "iConnect" which is another unit that works the same, but is installed by dealers only. They are both the same device.
http://www.shipsound.com/product_inf...ucts_id=103341
Old Feb 21, 2007 | 10:06 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Install was very easy. Hardest part was getting things torn apart and even that was pretty easy. I am sorry I really don't have any other pictures. The pictures I submitted at the beginning of this thread really show the just of it, but once you get the cord installed it is all about tucking things away. Just make sure you keep checking it when you reinstall everything to be sure nothing came loose, i.e. antenna.
If you have questions, just pm me or post here, I will check for any questions periodically.
Micah
