Sponsored by: Innova
Question about Bose cd player
Old Feb 26, 2007 | 03:11 PM
ewdalton's Avatar
ewdalton
1st Gear
Default Question about Bose cd player
I recently bought a 1991 Corvette and was wondering if the Delco Bose Gold Series cd player can be modified to play copied or burnt cds.
Old Feb 26, 2007 | 03:17 PM
ruby9246's Avatar
ruby9246
St. Jude Donor '03-'05-'06-'07-'08
http://www.doctordons.com/corvetteradios.htm
Old Feb 26, 2007 | 03:58 PM
BigDR's Avatar
BigDR
Default 1996 will play CD-R....
My 1996 Bose plays burned CD-Rs with no problems. It will not read a CD-RW.
Old Feb 26, 2007 | 04:07 PM
SJW's Avatar
SJW
I recently took the plunge and bought an 80GB I-Pod. It will hold my entire CD collection (approximately 1,000 discs), with a lot of room to spare.
I find the I-Pod, along with my Sirius satellite radio receiver, to be the ideal solution for music on the go -- especially in a C4 ragtop, with cargo space being at a premium. You might want to consider this instead of hauling a bunch of CDs around with you.
Be well,
SJW
Old Feb 26, 2007 | 05:51 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Originally Posted by SJW
I recently took the plunge and bought an 80GB I-Pod. It will hold my entire CD collection (approximately 1,000 discs), with a lot of room to spare...
Are you running the I-Pod through the stock stereo? If so, how? My experience with those gizmos that broadcast to an empty local FM frequency have been disappointing. TIA...
Old Feb 26, 2007 | 06:11 PM
dbriana's Avatar
dbriana
Not sure if it works or not, but I believe someone posted a while back that if you burnt it at the slowest speed 1 or 2 to 1 that it works? If you don't have them burnt already may be worth a shot.
Old Feb 26, 2007 | 10:26 PM
SJW's Avatar
SJW
In my C1500 I use an FM transmitter, because that's the only way in (no cassette deck, no line inputs). I've used it in rental cars for the same reason.
In my Vettes, I'll be using a cassette adapter. I also use this adapter to play the I-Pod through my stereo at work.
Be aware that not all FM transmitters are created equal. Some are much better than others. The one I have works well enough, as does the cassette adapter.
Be well,
SJW
Old Feb 26, 2007 | 10:28 PM
serge's Avatar
serge
From: Olympia Washington 91 Z07 Coupe, 6spd, Borla Exhaust, Perf. Ignition, K&N Filter
for the ipod, use a tape adapter with a headphone jack
Old Feb 27, 2007 | 12:00 AM
bogus's Avatar
bogus
there are also RF interfaces that will play iPOD's.
The later Bose units are more forgiving towards burned CDs than the earlier units. By 1996, home CD burners were marginally more common...
Old Feb 27, 2007 | 01:48 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I use a cassette adapter for my MP3 and it is even clearer than the stock Bose radio.
I also have an FM transmitter for the MP3 but it doesn't work well at all. It's the kind that just boadcasts to the car's FM antenna.
Old Feb 27, 2007 | 10:47 AM
jodyeastman's Avatar
jodyeastman
My 94 will play CD-R. I too burn on slow speeds.
Old Feb 27, 2007 | 09:40 PM
tobijohn's Avatar
tobijohn
Bench Racer
I've got the DLO Transpod (broadcasts to an empty FM frequency) and while it has some nice features for the I-Pod (http://dlo.com/Products/TP_Prod.tpl?command=showpage ), the fidelity is mediocre at best, not the "Crystal Clear sound" the packaging claims. I've got the Bose with both CD and cassette players so I could use a decent adapter for either. Which model of adapters are you using? TIA...
Old Feb 27, 2007 | 09:55 PM
Perfusion's Avatar
Perfusion
I use the tape adapter with my iPod. Never tried an FM Xmitter, but I've not really heard many positives about them from people who live in heavily populated areas.
Old Feb 27, 2007 | 09:56 PM
FOXX's Avatar
FOXX
Call me stupid, but I had this idea of leaving the stocker in it's place (my cd and cassette are both non functional) and using the drivers arm-rest as the home for a stereo of choice. Use a remote control for the levels and so on. I really hate thinking about removing the stock system even if it doesen't work. It just looks so cool in there. I'm using the iTrip with my iPod right now. It works but it's in no way as clear as I'd like.
On the above idea, I'd suggest getting a new armrest box (if they are available) and cut it up rather than make holes in your stock one. If done properly, it might just work out pretty well.
Old Feb 27, 2007 | 09:58 PM
tobijohn's Avatar
tobijohn
Bench Racer
Originally Posted by Perfusion
I use the tape adapter with my iPod...
Brand/model por favor?
Old Feb 27, 2007 | 10:07 PM
SJW's Avatar
SJW
The FM transmitter I use came from Best Buy recently. I believe the brand name is Griffin. It works satisfactorily, IMHO. Any FM transmitter will require a clear channel, which in an urban area can sometimes require some hunting around the dial, but it does work, and the fidelity isn't half bad. Not great, but not bad, and when it's the only way in, it'll do for me.
When there's a cassette deck present, but no line inputs, I use the cassette adapter -- fidelity is better than with the FM transmitter. I don't recall the brand name on mine, but I doubt there's much difference between any of them. I'll try to remember to look at it when I get to work tomorrow, and report back then. IIRC, I bought it at a WalMart in Florida last year when I wanted to use my discman in the Vette (Bose CD deck went Tango Uniform).
Be well,
SJW
Old Feb 27, 2007 | 10:36 PM
Brian9's Avatar
Brian9
Great.... its 10:35pm and you got me wondering if this will work on mine and you know im not gonna be able to go to bed until i try it
To Question about Bose cd player
Old Feb 27, 2007 | 10:59 PM
Brian9's Avatar
Brian9
Well my 95 has the Bose gold system and I just tried it and it works... All this time ive had this car and didnt think that it would because of something I had read I guess i should have tried it along time ago... This is great news since i was fixin to blow some cash on a mp3 player and that fm transmitter thing this thread just saved me about $100 or more bucks! Learn something new everyday on here
Old Feb 27, 2007 | 11:41 PM
Goldcylon's Avatar
Goldcylon
The tape adapter works great folks!!
Old Feb 28, 2007 | 06:39 AM
tobijohn's Avatar
tobijohn
Bench Racer
That's what everyone keeps saying but nobody mentions a particular brand/model...
