Sponsored by: Innova
Bose problems
Old Mar 3, 2007 | 06:54 PM
Ibuyvettes's Avatar
Ibuyvettes
Default Bose problems
On an 89 Corvette BOSE system. The stereo makes a buzzing whining noise when the radio is on no matter if the car is running or not. The noise is at a constant volume regardless of stereo volume. When the car is running there is also engine whine. I want to be sure as to what it is instead of throwing more parts at it. I replaced the AMP relay so it was not that.
Old Mar 5, 2007 | 12:52 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Speaker amps are going bad. Please read the C4 sticky at the top of the Audio section. You will have to remove them and send them out to be fixed.
Good Luck
