Sponsored by: Innova
Carpet match
Old Mar 30, 2007 | 11:04 AM
kactussjack's Avatar
kactussjack
Default Carpet match
I tried do a search on this a couple times but never found a definitive answer. I am building an amp rack for a '97 C-5 & would like to cover it in matching black carpet. Where can I buy carpet without heavy backing that will be the best match?
Thanks for your help.
Old Mar 30, 2007 | 12:25 PM
-=Jeff=-'s Avatar
-=Jeff=-
www.accmats.com
there is an option for ordering non-molded by the yard carpet.
I believe if you call they will send you samples
Old Mar 30, 2007 | 12:31 PM
scott_fx's Avatar
scott_fx
yup. they sent me samples and the carpet matched perfectly!
Old Mar 30, 2007 | 01:21 PM
kactussjack
Thanks guys- The samples are on their way.
Old Mar 30, 2007 | 02:14 PM
NVTHIS's Avatar
NVTHIS
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
Me personally, I didn't think the carpet was a perfect match, but it was close. Of course I have the black with the latex backing if that makes a difference. Definately don't get the latex backing on the carpet as it is a PITA to install on boxes and amp racks. Here is a pic of a Hangover box I done for a customer using the black. As you can see it matches closely, but the carpet pattern/texture wasn't the same and is a shade lighter.
Old Mar 30, 2007 | 04:16 PM
01QSZ06's Avatar
01QSZ06
Black Felt from walmart is a very close match and looks good inside. $3.77/yd
Old Mar 30, 2007 | 05:06 PM
scott_fx's Avatar
scott_fx
that's odd, mine matched perfectly
maybe it's a color thing
Old Mar 30, 2007 | 05:40 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Mar 30, 2007 | 06:14 PM
NVTHIS's Avatar
NVTHIS
Yeah, I can get the tan to match very close if not perfectly match, but the black is a shade lighter for some reason.
To Carpet match
