Sponsored by: Innova
alpine 7998 help needed
Old Apr 20, 2007 | 09:21 AM
pdd000's Avatar
pdd000
Default alpine 7998 help needed
my display keeps changing non stop going through all the displays. then it goes through the cycle again. any way to stop it and keep it on one display?? weird it never did that before. now i take the car out for the first time since last oct and the radio is nuts
Old Apr 20, 2007 | 09:44 AM
DPG's Avatar
DPG
St. Jude Donor '06
it has gone back into the display demo mode it seems like. Don't know how to change it but maybe you can look through your manual for something like that.
Old Apr 20, 2007 | 10:23 AM
Kale's Avatar
Kale
I think you should (carefully) tear that POS out of your dash and send it to me.
But seriously, I'm pretty sure that you have to turn the head unit off (with the car on) and then use the controls to turn the demo off. I think Menu... It's been about 2 years so I could be wrong.
Old Apr 20, 2007 | 11:42 AM
pdd000's Avatar
pdd000
ill check the manuel and see if i can find anything
Old Apr 20, 2007 | 12:12 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
its deff in the manual somewhere
Old Apr 21, 2007 | 01:10 AM
bogus's Avatar
bogus
if you hit the display button enough, it will stop... I think.
I have a 7998 (and no, Kale, you can't have it ), but I don't remember off hand how to get it. Check the Alpine website, they have the manual still available there.
Old Apr 21, 2007 | 01:19 AM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
i have a 7897 if the display continues to upset you I'd trade ya, just got it back from alpine the mechanism to pop the face popped itself instead of the face.
Old Apr 21, 2007 | 09:53 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
The display cycles through the different visuals....that's just how it is, Personaly it's the only feature of my 7998 that i don't like. I've read the manual many times trying to figure out how to lock a single pattern but that's just how it's programmed.
According to pg 16 of the OM, If you press the display button repeatedly, you can select the display you want and it will remain there for a little while longer, but eventually go back into the cycle.
Old Apr 21, 2007 | 01:29 PM
Kale's Avatar
Kale
That can't be right - Mine never cycled through the displays. That's the kind of thing tha would have made me pull it out of the dash and throw it out of the window.
Try this:
press and hold SETUP for 5 seconds.
You might have to use forward to go through a few things to find Demo
I think then BAND turns on or off the demo mode.
Then hit SETUP again to exit.
Old Apr 29, 2007 | 12:06 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Eureka!! it works!!!
Kudos to Kale!!!
the setup for 5 sec also gives you many other features not mentioned in the manual.
Old Apr 29, 2007 | 12:11 AM
Kale's Avatar
Kale
Kudos to Kale!!!
Glad it worked out.
To alpine 7998 help needed
