Sponsored by: Innova
Dynamat install question...
Old Apr 30, 2007 | 02:30 PM
Vortech C5's Avatar
Vortech C5
Default Dynamat install question...
Hello Everyone,
I am getting ready to put in some dynamat in my doors. When putting down a new strip, do I over lap the old one? If so, by how much? I was thinking 1/4 in.???
Please advise...
Thanks in advance!
Ray
Old Apr 30, 2007 | 03:40 PM
DPG's Avatar
DPG
St. Jude Donor '06
i do a 1/4" overlap
Old Apr 30, 2007 | 05:21 PM
fej's Avatar
fej
Personally I try and get it to lay as flat as possible. In areas where I am putting down more than one layer it makes it much easier IMO. 1/4" overlap I am sure is fine however.
Fej
Old Apr 30, 2007 | 08:49 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
IMO, overlapping doesn't really matter much. The purpose of dynamat is to increase the mass of a panel so it's less prone to vibration and the butyl compound is a vibration absorbsion material. As long as you get most of the surface, it should be fine.
However, if you want it to look right, my suggestion would be to overlap, then cut away the excess with a razor to make the edges meet perfectly.
Old May 2, 2007 | 12:10 PM
400Reasons's Avatar
400Reasons
Agreed. If I overlap I typically will overlap with a quarter sheet or more. Also, I get nervous about material edges near moving parts in doors or where they could snag. So sometimes I will run material until there is a depression in the metal or until its safely past the "snag point"
Just MHO
To Dynamat install question...
