Sponsored by: Innova
Dynamat Question
Old Apr 30, 2007 | 10:08 PM
mickey_7106's Avatar
mickey_7106
Default Dynamat Question
if i get this on my C5 will it stop the annoying rattle of the body when i got my music turned up. i have 2 10" MTX .
Old Apr 30, 2007 | 10:42 PM
Kale's Avatar
Kale
That or foam will. Assuming you apply it in the spot that is rattling.
Old May 1, 2007 | 10:06 AM
bbentley40's Avatar
bbentley40
Yeah.. as Kale said.. mat and foam (I used Frost King).. apply enough of it and in the right spots and your all set. I did basically the entire bottom of my car with the Frost King (trunk and cockpit) and it took 5 rolls (75sq ft). The Dynamat you can put in choice locations to deaden things.
Old May 1, 2007 | 11:05 AM
Kale's Avatar
Kale
Well if you use frost king, the foil might rattle against something.
I just use 1/8" closed cell foam. You can wrap it around rods, wires, and put it all over. I also stuffed every crevice with open cell foam that I could (packing foam)
Old May 1, 2007 | 11:18 AM
mickey_7106
i can really hear it by the gas door, the license plate and a small metal plate right above the drivers side exhaust.
Old May 1, 2007 | 12:28 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
you might just have loose screws. If that's the case a spring lock washer should solve your problem.
Old May 1, 2007 | 12:57 PM
DPG's Avatar
DPG
St. Jude Donor '06
To Dynamat Question
