Sponsored by: Innova
Antenna dilemma
Old May 19, 2007 | 06:37 PM
00 NBFRC's Avatar
00 NBFRC
Default Antenna dilemma
I bought my FRC with a shorty installed. It is starting to pit and the reception has been horrible. So its probably time to replace it. I dont really want to go back to a stock antenna for a RC car look.
Are any shortys better than others?
Is there anyway to "calibrate" or "tune" the antenna to the radio like back in the day?
Old May 20, 2007 | 10:05 AM
00 NBFRC's Avatar
00 NBFRC
I found this one for sale. Emailed the seller and he said it would fit as long as the car didnt have the power antenna as o.e. They are avail. in 6, 9, 12" lenghts.
http://cgi.ebay.com/ebaymotors/CHEVY...QQcmdZViewItem
Any thoughts?
Old May 20, 2007 | 04:15 PM
DPG's Avatar
DPG
St. Jude Donor '06
don't have any experience with that model or brand. You can do what many others have with their stoc antennas. Just chop it down, repaint it and you can add a cap to the top or transfer the ball from the cut piece and add it back to the chopped antenna
Old May 20, 2007 | 11:44 PM
00 NBFRC's Avatar
00 NBFRC
Nice plan, thanks for the tip. But since I dont have the o. e. antenna, I will have to buy one. Your plan, if it was in chrome, would be the choice. Thanks.
Old May 21, 2007 | 01:19 AM
DPG's Avatar
DPG
St. Jude Donor '06
no problem, im sure you can pick one up at a junk yard maybe.
Old May 21, 2007 | 01:56 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
fyi same antenna used on 4th gen fbodies and like a thousand other gm cars should thread right on
Old May 21, 2007 | 02:52 PM
BitViper's Avatar
BitViper
There is another solution...loaded base...all rubber weather proof construction..
PM me
Old May 21, 2007 | 06:19 PM
00 NBFRC's Avatar
00 NBFRC
I would like to get one off a gm car that is chrome. Cut it and cap it. With the chrome Z06 wheels, I think a chrome mast would match best.
What models had chrome masts that would thread on?
Old May 22, 2007 | 09:43 AM
DPG's Avatar
DPG
St. Jude Donor '06
im not aware of any stock chromed antenna masts that came from the factory. an email to gene cully at gm parts might help you narrow a model down
Old May 23, 2007 | 12:42 PM
doctorstork's Avatar
doctorstork
will this fit on a 1991...where did you get it?
Old Aug 27, 2007 | 01:51 PM
bighank's Avatar
bighank
Default Older radios had a trimmer capicitor to "tune"
Haven't pulled the radio from my C5 but have worked on a lot of older car radios...some with TUBES IN THEM. They all had a trimmer capacitor which had a screw slot accessable from the outside of the radio. Usually near where the coax cable went into the radio chassis. You used a small screwdriver. Tuned to a MEDIUM to WEAK signal near the middle of the AM band like around 1000 KC and turned the adjusting screw either right or left until the signal was at the maximum volume from the speakers. Don't know if the current radios have this or not but after replacing an antenna in the OLD DAYS I ALWAYS set the trimmer capacitor to get the most signal from my radio. BIGHANK
Old Aug 29, 2007 | 09:24 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
No, the '91 had a power antenna. The screw on type are for fixed mast antennas.
The biggest problem I see with a lot of the antennas are the aren't tuned. The length of the mast/coil plays a hudge part in the reception capabilities. Chopping an antenna down will shorten it as well as shorten its receiving capabilities.
Remember also, our cars are crippled by the lack of a large ground plane that most cars have via the steel body. That translates to a less than optimal receiving setup. IIRC, there is a booster in the OEM receiver that kicks the RF up before it gets to the tuner.
To Antenna dilemma
