Is this a Good Sub?
when it comes to choosing the right equipment for your setup. You have to read, read, read (or post details and ask) to learn for yourself what specs you should look for to meet your goals.
A little knowledge can really help spot those drivers with questionable specs. And there are a lot of them out there.
I mean ,whether or not you like high horsepower cars, it's easy to say that if you want a slow car, you want 150hp, and if you want a fast car, you want 400hp. And if you want to tow, you want good low end torque, but if you are road course racing, you want lots of power up top...
Rob is obsessed with getting the best possible result, compromise is not in his nature. If you tell him that you have a box with a certain airspace available and what your goals are for the sound I'm sure he would be more than happy to point you towards the kinds of drivers and specs to keep an eye out for. But to speak in generalities... definitely not his nature.
Trust one thing, he's not saying what he's saying to be a contrarian, he's genuinely trying to provide information. He's just not very good at doing it.
Hi Rob
My idmax sounds very much different sealed in my corvette than it did in my tacoma, for example.
There are many proven performers in the audio world, some lesser known names that make great drivers, and some very well known names that make some poor performers.
Certain things hold true in car audio, like the correct enclosure for any given sub will outperform a great sub in a poorly designed/suited enclosure.
I have heard $5k sub setups that sound like shyt, I have heard $200 sub setups with a 6" sub sound phenomenal. One of my most classic memories was my buddies Taurus with Cambridge Soundworks home based sub enclosures (basically 2 slave units with 2 6" drivers each) that flat out HAMMERED. Played really low with clean and tight accuracy. People would always ask how many 12's he had or if he had 2 15's ... another example of great enclosure/driver matching.
IMO at some point you need to spend a few dollars on your drivers however, as a $70 sub can, but is not likely to outperform AND outlast a $150 sub. Case in point is all of the old PPI and Soundstream gear that still carries a great reputation and solid quality 10-15 years after it was sold new. Audiobahn (no offense) will never have their gear do the same.
Fej
Back to the point of this thread... the Focal is an excellent choice for certain applications. It can't be dismissed out-of-hand for a spec that many people can't grasp. Since we have yet to hear what his actual design goals are, that's all that can be said.
And for maybe the first time, I completely agree with fej.
I have different subs in the four vehicles I own.
The 1991 Jimmy SLE 4X4 has two JL Audio 18W6s with each getting 900watts rms
It is the loudest of the vehicles I own. I'm not lying when I say the subs cracked my windshield and has knocked off my radar detector.The 2002 Vette has three Infinity Perfect 12.1Ds, again loud but more controled bass.
The 92 Eagle Talon TsiAWD has both two ID 8"s up front and four ID 10"s in the hatch. In SQ competion the 8"s are used but for SPL the four 10"s are used and have hit 147 dbs
. The 1991 Eagle Talon TsiAWD had four JL Audio 15W5s (they were stolen
) in a iso configuration, they were awesome too.IMO, Focal makes excellent speakers. I use a set of Focal componet speakers in the 92 which has won MANY awards......but the Focals were nearly $1,000
The JL Audio 12W7 is one of the best subs out there. But, it too is big $. So, I agree with the others, the ID would probably be a good sub for you.
Jay
Key Features
• 160 Newtons2/watt Motor Force
• 1000 Watts Continuous Power
• 3" Anodized Aluminum Voice Coil
• Single Dish Titanium Cone
• High Excursion Tall NBR Surround
• 215 Ounce Magnet Structure
• Anti Flux Modulation Shorting Ring
• 30mm XMax
• 10" Diameter Suspension System
• Custom Cast Aluminum Frame
• Quick-Detach Top Assembly
Driver Cutout Diameter Basket Diameter Gasket Height Mounting Depth Displacement Weight
12TC-3000 11.25" 12.65" 0.65" 9.75" 0.12ft3
Using this Amp to Drive it.
Features:
o Brutus BXi 2006D
o 1-Channel Mono-Block Operation
o SUPER D-Class Ampllifier Topography
o Ultra-Fi MOSFET Outputs
o Illuminated Hifonics Logo
o PWM MOSFET EXVP (Exponential Vari-Power Supply)
o SPC Twin Turbo-Torroids with Simpatico Coil Design
o Remote Bass Control
o Balanced Line Inputs w/ Optional Hifonics MM-BLD-1
o Gold RCA Line Ouputs - Permit Amplifier Daisy-Chaining
o 4-Gauge Power Connectors
* Fully Adjustable Accu Cross Crossovers Inlude:
o -24dB Subsonic Filter (Adjusts 15-50Hz)
o Phase Shift Adjustments (0 to +180 Degrees)
o 24dB Low-Pass Crossover (Adjusts 35 - 250 Hz)
o Bass Boost: Variable Bass Equalization (+18dB @ 45Hz)
* SPECIFICATIONS:
o 650Wx1 RMS @ 4 ohm
o 1300Wx1 RMS @ 2 ohm
o 2000Wx1 RMS @ 1 ohm
o S/N Ratio: >95dB
o THD & Noise: <0.08
o Input Impedance (Balanced/Un-Balanced): 20k ohm / 47k ohm
Front Door Speakers
FOCAL POLYGLASS 165V3E
6 1/2" THREE WAY COMPONENT SYSTEM
3 Way Separate System
165mm Woofer
25mm Voice Coil
84mm Magnet
100mm Mid-Range
25mm Voice Coil
Neodymium Magnet
TN 47 Tioxid Tweeter
3 Way Separate Crossover
12 dB/oct. (3.5kHz)
Adjustable Tweeter Level
160 Watts Max Power Handling
80 Watts Nominal Power Handling
93dB Sensitivity (2.83 V/1m)
55Hz-20kHz Frequency Response
Grills Included
front door amp
* RMS Power Range : 250-500 Watts
* Number Of Channels: 2
* Maximum Power: 1000 Watts
* Built In Crossovers: Yes
* Channel Separation: Yes
Features
* RMS @ 4-Ohms: 2 x 250-Watts
* RMS @ 2-Ohms: 2 x 500-Watts
* RMS @ 4-Ohms: 1 x 1000-Watts
* Crossover And Switching:
o Variable 12dB Octave Hi-Pass
o Variable 24dB Octave Low-Pass
o ±18dB Bass Boost at 45Hz
* Inputs and Diagnostics:
o Variable Input Level Control
o Power and Diagnostics LEDs
o DC Short Circuit Protection
o Over-Load Protection
* Connector Types:
o Unbalanced Inputs (RCA’s)
o Full-Range Line Outputs (RCA’s)
o Molded 4-Gauge Power Inputs
o Molded 10-Gauge Speaker Outputs
Sub almost 10 inches deep.. I going half to do some type of custom sub
box.
All this Audio has nothing but got high praises from all around the internet. I know it can be
Guys and Girls, Tell me if I'm getting way off base here. Don't hold back,I
can take it...
Also Thanks for All the super good info in this Thread.... I'm sure alot more people will get alot of good info from it...
This will prob. be the last system I will do, I'm getting little old for all the
bump in the Trunk thing.. So going out with a BANG..
To Forum Gurus............ THANKS
http://www.tcsounds.com/tc9.htm
check out this:
http://www.diymobileaudio.com/forum/...1&postcount=14
from this thread:
http://www.diymobileaudio.com/forum/...ead.php?t=8694
the member that i linked to is a very well respected member on that site that does a ton of testing and evaluations.
TC sounds makes some great subs .. I have one of their 12's sitting in my room waiting for a home right now ... could not pass up the price heh. 10" deep is going to take some sort of volcano or other custom mount as my 5.75" deep 12" sub barely fits in a stealth style flat top box.
G'luck on your auditioning, there are lots of great sets out there, but YOU have to like how it sounds. Make sure you listen to component sets with similar power ratings to what you will be giving them, and without outside subs or processing so you can get a true feel for what they will sound like in your car. Also be sure to bring music that YOU know well and know what it should sound like.
Fej
It should also be mentioned that the placement and quality of the enclosure has a lot to do with the reproduction of bass notes. For example a larger box may hit lower, but be sloppy, and a smaller box may be better suited to quick notes, but has a hard time hitting low.
To solve some of this, I tend to over-power my speakers. My sub has a 1000.1 JL audio on it (1000watts rms), for example. I place it in a mid sized box that is a sacrifice between the two extremes and with the added power it helps me hit the low stuff while maintaining accuracy.
The sub I had before the Diamond was a MBquart. I'm really not a fan of Quart's components but their high end subwoofer is really good. It was less power hungry than the Diamond Audio, but not as good.
Have fun with it and buy what sounds good to YOU, not us! The hobby of car audio is in the search for what sounds good to you. I think what you realize when you get better and better equipment is that its just too painful and expensive to get better after a certain point. Eventually you learn that 90% of perfect is just fine. That last 10% =
Fej
last 10%
Hit the nail on the head, you are so right..
check out this:
from this thread:
Great Post. Thanks
Peter
