Sponsored by: Innova
Is this a Good Sub?
Old Jun 13, 2007 | 03:33 AM
  #61
montyzuma's Avatar
montyzuma
Subwooer, I see now how you got your name. :-)
Your box is so sweet. Can you say HEAVY DUTY..
Thank you for posting your pictures.
Do you think I could do it out of plexiglass for the top and mdf for the
bottom?
I didn't realize how much 30 degrees would change the look. Wow
Old Jun 13, 2007 | 09:59 AM
  #62
Subw00er's Avatar
Subw00er
Originally Posted by VinceC5
Can you tell me the max mounting depth of the subwoofer for the box that you made? I have an MTX 9512 that I need to build a box for.
Its probably around 7.4in. You can figure it out exactly by doing some math on the drawing above.. but thats probably a really close guess. You'll want to leave at least .5" below the subwoofer's magnet for clearance.
Old Jun 13, 2007 | 10:03 AM
  #63
Subw00er's Avatar
Subw00er
bottom?
Thanks! ya I"m sure you could if you got someone to cut the pieces first. Cutting plexi is a pain because the edges are bad if you jig saw them..
I'm not sure of the best way to join plexi to mdf, although I'm sure its done a lot. In this instance its hard because of the difficult angles at the top, but if you had a thick sheet for the top and then went into mdf on the bottom, you'd just drill holes and countersink the holes and then screw it together?
Easier: why dont you make a MDF box and then over the mdf top sheet (Where the woofer goes), place a plexiglass sheet cut to the same size - cut out a hole for the woofer and then it will be easy to drill together because its more of a sandwich. You could even lift it .5" with spacers for a neat effect and throw your LEDs in there. The woofer can even be mounted below into the mdf, below the plexi, and then have that website cut a grill out of it for you.
Old Jun 13, 2007 | 10:24 AM
  #64
Fasthotrod's Avatar
Fasthotrod
I did the math on the clearance... maybe someone could check my work to see if I'm right?
At the top of the peak where the 16.5 and 7.12 meet is a 90.2 degree angle.
The angle on the right where the 7.12 and 11.2 meet is 100.42 degrees.
This should make the difference in angles between the 16.5 piece and the 11.2 piece is about 10.22 degrees.
Based on that, I would imagine that the difference in depth goes from 7.12 inches to just over 9.13 inches where the 11.2 meets the vertical at the 1.75 number.
The middle of that would be about 8.125 inches if my math is correct.
The overall depth for mounting a sub would depend on the drivers diameter, it's actual depth, the magnet diameter, and it's mounting location. If you have the driver specs, I can probably figure it out for you.
Let me know if this helps, or if my math is completely hosed.
Mark
Old Jun 13, 2007 | 10:27 AM
  #65
Kale's Avatar
Kale
This is what I did to fit the very deep idmax:
unfinished box:
Though i'll downsize my system soon and put in a small stealth 10, maybe...
Old Jun 13, 2007 | 11:21 AM
  #66
VinceC5's Avatar
VinceC5
thanks all for the responses, I really like the way that box faces the rear, but unfortunately, I need a bit over 10" for my MTX9512. I think Scott's pic/design in post #47 will give me that.
Hey Scott, how about some detailed measurements for that? I do like the idea of a plexi-glass top...with mirrors in the inside
Old Jun 13, 2007 | 12:28 PM
  #67
scott_fx's Avatar
scott_fx
detailed measurements....hmm that's going to be tough. i just modeled that quickly with out taking any measurements and I did it in Maya not a CAD programs so it's definately not accurate, it was just done as a proof of concept type thing.
Old Jun 13, 2007 | 01:33 PM
  #68
montyzuma's Avatar
montyzuma
Subwooer, This just hit me.. I have a coupe. The Targa might not fit.
Need to do some measurements with the targa in the hatch.
Old Jun 13, 2007 | 01:34 PM
  #69
montyzuma's Avatar
montyzuma
unfinished box:
Kale, You have your sub pointing to the rear and Subooer has it going to
the rear at 30 degrees. If I reversed it to point to the front like 20 or 30 degrees, Does that effect the SQ any?
Nice sub box, When you take it out you could use it for a School project for a kid. Kinda looks like a Volcano. You could name it Volcanobox and get rich selling them.. :-)
Old Jun 13, 2007 | 01:49 PM
  #70
montyzuma's Avatar
montyzuma
I had to read this couple times, to get your point. Didn't think about doing it that way.
You could do a lot of cool LED's lighting this way.
I'm going to some pondering for sure.
Old Jun 13, 2007 | 02:29 PM
  #71
scott_fx's Avatar
scott_fx
i kinda like the idea of just having a ring of plexi (1/2" or so) around the woofer and then light the box so that it glows. i may have to steal this idea :-)
Old Jun 13, 2007 | 04:01 PM
  #72
montyzuma's Avatar
montyzuma
How about taking something like this (pic below) and wraping it on the
inside of the plexi, glowing outwards? With your favorite color. Red for me.
http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget
Old Jun 13, 2007 | 10:19 PM
  #73
Subw00er's Avatar
Subw00er
Kale, You have your sub pointing to the rear and Subooer has it going to the rear at 30 degrees. If I reversed it to point to the front like 20 or 30 degrees, Does that effect the SQ any?
It will affect it big time. Its a big mistake to point it forwards in my opinion. In playing with the prefab box before I made mine, forward was the worst location. I'd choose a different, lower profile, sub before I pointed it forwards. Maybe you can go with two 8" or a 10"?
Old Jun 13, 2007 | 10:25 PM
  #74
Kale's Avatar
Kale
Ditto.
Old Jul 9, 2007 | 02:23 AM
  #75
jmlaudio's Avatar
jmlaudio
Thanks for the support Montyzuma. I see you are a man who truly appreciated custom one off hand made plexi work here. No cnc computer made things here. All of our custom plexi creations are hand made. At the end of the day we are fabricators not computer programmers.
