Sponsored by: Innova
C5 rear speaker replacement Help
Old Sep 7, 2007 | 01:49 AM
RedRiderZR1's Avatar
RedRiderZR1
Default C5 rear speaker replacement Help
So I have been looking all over the place on info on how to replace the rear speakers on my C5 coupe. I can't find any info on how to do this. Lots of install info on here BUT for the rear speakers. I'm guessing people don't install them when getting rid of the BOSE. I want to install some. Anyone have any idea how to change them out.
It could be as easy as pulling the cover but I don't know. Either that or pull the whole plastic surround out. I'm sure someone has done this. Any help would be great. Bought the speakers but don't want to tear into it and mess something up.
Greg.
Old Sep 7, 2007 | 01:55 AM
SilverC54me's Avatar
SilverC54me
Greg
I have done the whole system replacement. I can help you do the swap.
Gary
Old Sep 7, 2007 | 02:12 AM
RedRiderZR1
Gary,
I might take you up on that. I am going over to a friends tomorrow to do a speaker install on his jeep. Was thinking of tearing mine apart at the same time. If I don't I will give you a call and see what your schedule looks like. I finally found the info. Apparently the rear covers are pop off so It would be a breeze.
Have an amp and subwoofer installed. Just need to wire in the new speakers. Was just looking up how to take the door panels off.
Greg
Old Sep 7, 2007 | 02:21 AM
SilverC54me
Greg
The C5 comes apart so easy. It took me about 6 hrs. to remove all of the interior when I did mine. Before installing, I did put in sound deading (I used B-Quiet - a lower cost version of Dynamat Extreme). I am busy after work Friday, but should be available all morning Saturday.
Gary
Old Sep 7, 2007 | 02:25 AM
RedRiderZR1
If I don't do this tomorrow I might just give you a call Saturday morning.
Greg
Old Sep 7, 2007 | 10:04 AM
wildwall's Avatar
wildwall
Check out this web page-
I changed mine in about 2 hrs-
http://www.spdkilz.com/techtiprearspeaker.html
Old Sep 7, 2007 | 10:15 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
in a coupe the metal grill should pull right off, no need to remove panels
Old Sep 7, 2007 | 10:37 AM
Kale's Avatar
Kale
pop the metal grills off as said, undo old speakers, throw a couple spade clips and plug in new speakers, whole process is a 15 minute job, if you stop for beer.
Old Sep 7, 2007 | 12:04 PM
leolufse's Avatar
leolufse
where are the posts about no rear fill needed? c'mon guys
Old Sep 7, 2007 | 12:48 PM
Kale's Avatar
Kale
Rear fill supports terrorism.
happy now?
Old Sep 7, 2007 | 01:55 PM
RedRiderZR1
Thanks for the help. Hopefully it is only a 15 minute job for the rear speakers. Fronts will be a little more involved. Bought adapters for the front speakers. Just have to figure out where I am going to mount the crossovers. Pretty straight forward though.
To C5 rear speaker replacement Help
