Sponsored by: Innova
PAC OEM again...
Old Oct 25, 2007 | 05:27 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Default PAC OEM again...
Still need help getting the remote amp turn on to work. I tried the blue/white wire (supposedly is the one to perform this task), but no luck. Emailed PAC and techy says to "connect the green wire to pin 8 on the black plug"....not sure what he means; car dash is back together one more time, so before I go back in there I need verification and direction on how to do this. If it doesn't work, can't I just find a source of switched power and tap into that? What is the easiest place to find switched power? thanks...
Old Oct 26, 2007 | 02:42 PM
$$$frumnuttin'
I am forgetting the pac; which fuse should I run to for ignition on power?
Old Oct 26, 2007 | 04:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It is the dark green wire on the radio's harness, A8
Old Oct 26, 2007 | 04:29 PM
DPG's Avatar
DPG
St. Jude Donor '06
thats the one
Old Oct 26, 2007 | 07:37 PM
$$$frumnuttin'
Ok, I'll have to try that again...so I should use one of those connectors that lay the wires side by side, then snaps down on them..the 2 green wires?
Old Oct 26, 2007 | 07:42 PM
$$$frumnuttin'
Oh, one more thought...do I attach the green wire or the blue/white wire to the dark green wire? the kit says the blue/white wire is the remote turn on, but this doesn't agree with using the green wire which is the other loose wire on the PAC...what a can or worms!
To PAC OEM again...
