Sponsored by: Innova
Paging 99HT - Amp Install
Old Nov 19, 2001 | 01:04 PM
MAGRED 02's Avatar
MAGRED 02
Default Paging 99HT - Amp Install
I have had trouble installing a Punch 120a Amp and a 10" JL Audio Sub. Car Toys could not make it work. They told me there wasn't enough audio signal from the rear speakers to give the amp full power. I told them about the preouts that you have mentioned and they didn't know what I was talking about. I want to do this myself but I'm not very good at this stuff. The information you have given, is it something that a novice would able to do???? Also is there anything different on a 2002 Bose system???
Old Nov 19, 2001 | 03:26 PM
99HT's Avatar
99HT
Default Re: Paging 99HT - Amp Install (JMs99C5)
I hope you got your money back for the install and they did not damage your wiring. The HU pre-amp outputs are as follows:
Signal CD/Radio Color code
LF out C4(9) TAN/BLK
RF out C4(10) LT GRN/BLK
LR out C4(11) BRN
RR out C4(12) DK BLU
Shield C4(14) Bare wire
You can use the front or rear pre-amp outputs. It depends on how you want the fader to work. Most people use the rear. Use long RCA cables with one connector cut off to tap the wires. Make sure you get good power and grtound connections to the amp.
Do a search on this subject, it has been covered numerous times before.
Old Nov 19, 2001 | 04:35 PM
MAGRED 02's Avatar
MAGRED 02
Default Re: Paging 99HT - Amp Install (99HT)
Thank You Sir!!!!!!!! I think I am feeling a little bit brave, just might tackle it myself.
No I didn't get my money back because they had already put holes in the back panel so I couldn't back out of it. I had to buy a new HU. I got it at 25% off, didn't pay any installation fees or for the three parts that were needed to connect the aftermarker HU to the Bose Speakers. I WAS SO PISSED!!!
That was on my 99C5, I don't have that car anymore I now have a 2002. I'll be damned if I'm taking my new baby back to them. DO NOT GO TO CAR TOYS ON WESTHIEMER IN HOUSTON TEXAS!!!!!! :nono: They do not know how to work on C5's.
Old Nov 19, 2001 | 05:19 PM
earlybird_66's Avatar
earlybird_66
99HT,
Can't seemed to locate the detail instruction for hooking up an amp for the sub. I didn't order my 02 couple with a CD changer (I think I should have, its gonna be here in about 3 weeks). Two questions if you have time. 1. Do you still have the detail instruction on hooking up a sub amp. 2. Can I buy an aftermarket CD changer unit? if so, what is the pin configuration? basically what brand do I need to buy? Where can I buy the wire harness? Will it be compatible with the CD HU?
Thanks,
Old Nov 19, 2001 | 08:07 PM
99HT's Avatar
99HT
Default Re: Paging 99HT - Amp Install (earlybird_66)
The basic info for hooking up a sub amp is above. Do a search for more info.
You can add a CD changer any time on the future to a C5. Be sure to buy the GM unit that does NOT have the RF interface. It takes longer to install, but has better sound.
Old Nov 19, 2001 | 08:18 PM
Closer_2001's Avatar
Closer_2001
Try Searching Archives
To Paging 99HT - Amp Install
