Sponsored by: Innova
Removing stock Bose causes DIC code??
Old Jan 7, 2008 | 08:15 PM
ssmith512's Avatar
ssmith512
Default Removing stock Bose causes DIC code??
Getting ready to remove the entire stock Bose system from my 2002 C5Z. I believe it is integrated into the vehicles computer system somehow with the memory presets, etc.?? If so, after I unplug all the plugs on the backside of the stock headunit to remove it, will this cause the DIC to display a constant code after I complete the installation of my aftermarket system or does the computer not care if the bose headunit is plugged in or not.?? If so, is there a way to "disable" this code causing condition? Thanks in advance. Still trying to learn everyhting about this "new" car.
Old Jan 7, 2008 | 09:01 PM
heavymetals's Avatar
heavymetals
I just picked up all the wiring adapters.
I am doing the same project.
Don't know about getting a DIC code, but these are supposed to be the ticket.
PAC OEM-1
PAC AMP-VET1
PAC RAD-UNV
I don't know if I will have to use all three (I was told I would), but I didn't want to get stuck.
(UPDATE) Well right off it looks like I don't need the OEM-1
I replaced the speakers and I am adding an amp.
Old Jan 7, 2008 | 10:57 PM
SilverC54me's Avatar
SilverC54me
No codes are displayed when the head unit is removed.
Gary
Old Jan 7, 2008 | 11:00 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Gary
You will get a no communication error when you manual flip thru DIC for codes, but it is no big deal.
Old Jan 8, 2008 | 09:00 PM
ssmith512's Avatar
ssmith512
Thanks for the responses!!
To Removing stock Bose causes DIC code??
