Sponsored by: Innova
installing AUX input
Old Feb 4, 2008 | 04:41 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default installing AUX input
I'm debating on whether to install L/R rca jacks or just go with a 3.5mm plug.
I've heard that RCA can be grainy-sounding, but 3.5mm kinda limits me.
Thoughts?
Old Feb 4, 2008 | 08:38 AM
TheKomoman's Avatar
TheKomoman
St Jude Donor '13
Thoughts?
It's 6 of one, half-dozen of the other. They're just 2 different kinds of plus for exactly the same connection. 3.5mm is easier to use and there are plenty of adapter cables to connect standard 1/4" RCA jacks to the smaller connector.
Old Feb 4, 2008 | 10:50 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'd go with RCA for the sole reason that if you want to use a 1/8" stereo input, it's easier to find a 1/8"stereo-RCA than a RCA-1/8" stereo.
Old Feb 4, 2008 | 11:13 AM
scott_fx's Avatar
scott_fx
you only have to find the adapter once ;-)
http://www.vpi.us/cable-audio.html
go with what you'll use most. if you have an ipod then go with the rca's and use the doc connector for a line level output.
Old Feb 4, 2008 | 02:30 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I do not have an IPOD. I'm not that up on my music.
I have a 512MB Sayno MP3 player, which is 3.5mm, or I use my LG Chocolate phone, which has a 2.5mm plug (easy enough to put into 3.5mm).
Although, as I searched around, I found it wouldn't be that difficult to have both RCA and a 3.5mm, just a few extra bits of wire.
I was looking into RCA simply for expandability (since most aftermarket heads use RCA).
I'll probably go with just a 3.5mm, as it'll make finding space to mount it in the dash. and make my own adapter. I am an Electronics Technician, might as well make use of that at home.
Old Feb 4, 2008 | 05:32 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have the Aux box, The sound is fine, no static or grainy sound. Sounds like a CD to me.
To installing AUX input
