Sponsored by: Innova
Multiple subs off one channel?
Old Feb 27, 2008 | 12:15 AM
95ttoplt1's Avatar
95ttoplt1
Default Multiple subs off one channel?
Hey guys I have bought a 5 channel 1200w Boss Amp, and I was planning and running the fronts off of two channels, the rears off two channels leaving one channle for the subs.
I bought (2) 10" Sony X-plode 1100w Subs(might not be the best but they look cool and are in the budget). These will be mounted in a partition box in my coupe. facing the rear of the seats.
My question is how should I wire these off of the one channel?
Old Feb 27, 2008 | 12:27 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
depends what is ur amp stable to on that sub channel, are your subs SVC DVC 4ohm 2ohm. With a boss amp if its not stable and thats how you wire it your sure to blow the amp
Old Feb 27, 2008 | 12:43 AM
95ttoplt1's Avatar
95ttoplt1
Here are the subs I bought
http://cgi.ebay.com/ebaymotors/ws/eB...197309038&rd=1
And here is the amp
http://woofersetc.com/index.cfm?fuse...roduct_id=6061
I know its not the best stuff but I'm on a budget
Old Feb 27, 2008 | 12:45 AM
VinceC5's Avatar
VinceC5
is it the gt980?
1200W Riot GT Series 5-Channel Amplifier
4 ohms: 80 watts x 4 chan. + 150 watts x 1 chan. RMS
2 ohms: 200 watts x 4 chan. + 400 watts x 1 chan. MAX
don't go lower than 2 ohms on the sub channel. I think your subs are 4 ohm/SVC subs, so hook them up in parallel and you should be ok.
Old Feb 27, 2008 | 12:46 AM
VinceC5's Avatar
VinceC5
And here is the amp
you know walmart sells these subs new with warranty for $59....
Old Feb 27, 2008 | 01:27 AM
95ttoplt1's Avatar
95ttoplt1
I got two for $102 shipped with a warranty, so it looks like I did ok
Just so I understand this correctly, I have two wires comming out of the sub, that should be split into two each, and then ran to the subs?
Thanks for the help
Old Feb 27, 2008 | 01:30 AM
VinceC5's Avatar
VinceC5
Just so I understand this correctly, I have two wires comming out of the sub, that should be split into two each, and then rane to the subs?
Thanks for the help
You did good!!!
They should be wired like this:
Old Feb 27, 2008 | 01:33 AM
95ttoplt1's Avatar
95ttoplt1
You did good!!!
Sweet, that makes it super simple. Thanks for all your help.
I will post pictures when I get it all installed
To Multiple subs off one channel?
