That connector is the industry standard. The GM connector is tiny and allows almost a 90 deg bend of the cable. You will need two adapter cables, it may be hard to find both sexes.
What is most important in an FM modulator is the signal to noise ratio and the distortion. Being very accurate in frequency is also important, but most new modulators on good CD changers are very accurrate in frequency.
You also need to know that the modulator does not generate interference on the AM or FM bands and that the loss through it when off, is not too large.
JMs99C5 please post results if you try the FM modulator. I am also quite interested.
I will - I have to wait until after January 1 until I can purchase the parts. But I will document everything during the install. If it works then I will post all the parts needed, instructions and maybe some pics.
