Sponsored by: Innova
C3 Mounting depth?
Old Dec 16, 2001 | 05:07 PM
ridged84's Avatar
ridged84
Default C3 Mounting depth?
I know the mounting depth on the front stock speakers are 2" .So my question is can i get away with a deeper one . this is for a 72 coupe. :confused:
Old Dec 17, 2001 | 10:02 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: C3 Mounting depth? (ridged84)
You have to try fitting it. They are all different. You may need to file or cut a little to make it work. What you need to avoid is getting the speaker in a conflict with the window and its mechanism. As long as you avoid that, you'll be fine. You can also add a spacer. This is a ring that fits behind the speaker that has the speaker mount 1/2" out from the door panel. Not as pretty, but it works. Most good speaker makers make these to blend in with their speaker covers seamlessly. :cheers:
Old Dec 17, 2001 | 06:37 PM
ridged84's Avatar
ridged84
Default Re: C3 Mounting depth? (92TripleBlack)
Let me clear this up a little. My speakers are in the dash and i want to replace them . I need to know what the deepest i can go
Old Dec 18, 2001 | 10:18 AM
92TripleBlack
Hmmm, don't know the dash speaker size/depth for a 72. For an 80 it was a 4x6 and you pretty much could put any speaker that would fit in that size hole there. Maybe check the C3 area. It would really depend on how they designed the ducting, etc on the earlier C3s.
Old Dec 18, 2001 | 07:52 PM
ridged84's Avatar
ridged84
4x6 is the speaker size i need to know the depth
Old Dec 19, 2001 | 02:06 PM
92TripleBlack
YOu should be able to fit just about any 4x6 speaker in there. I don't know of any that are deep. You may have problems with 4-4 1/2" as their magnets are bigger. Only way to know really is to open it up and look. If you need help, I'm pretty much in the area and I'll be around this weekend. :cheers:
[Modified by 92TripleBlack, 1:07 PM 12/19/2001]
To C3 Mounting depth?
