Sponsored by: Innova
Insane Work In Progress Sq Build
Old Jun 9, 2008 | 08:56 AM
DPG's Avatar
DPG
St. Jude Donor '06
try rolling the window down, then putting the panel in. you have to put the top on with a little bit of an angle and there are 3 metal clips that at the top. you need to seat those first. if you looks at the front of the door where the weather stripping is, you'll see that there is a curve in it with a raised lip. get the door about 1/4" off that raised lip this should line up the metal clips and bottom plastic clips very nicely. if the door has never come off before it will be a little more difficult to put back on. but you have to push down first with the metal clips up top.
Old Jun 10, 2008 | 10:38 AM
lexizpimpin's Avatar
lexizpimpin
will def try thanks for the suggestion im also looking for a nice looking cheap distribution block
Old Jun 10, 2008 | 10:52 AM
Kale's Avatar
Kale
Stinger makes good quality stuff at a mid level price point. I've had one for years that's been flawless. Tsunami comes to mind as well.
Old Jun 10, 2008 | 02:52 PM
Fasthotrod's Avatar
Fasthotrod
Originally Posted by lexizpimpin
i need a picture of someones door insulated because i want to see what part of the deadeing i need to remove for the door panel to seat properly
Like this?
The Styrofoam enters the door cavity, so if your deadening is covering that you will have problems. You also need to be careful of the upper lip where the door panel attaches to the door. You can see a distinct line where the Ensolite stops on the top of my door panel.
Pentavolvo is also correct. If the speaker plate is too thick, it will hit the door panel and/or window switches. That's one reason that I went with the thin plates.
Also... be aware that the door panel may block those mids. Here are some pictures of what I mean:
Notice that as the angle changes, you lose the off-axis access to the driver. You might be better served to make some kick panels for the mids and tweeters.
Mark
Old Jun 10, 2008 | 02:56 PM
Kale's Avatar
Kale
eh, midrange sharing airspace with the midwoofer can cause enough problems I dont think the blockage will make that much of an extra difference. would suggest open cell foam on that part of the door though, to help reduce reflections inside the odor panel.
Old Jun 10, 2008 | 03:42 PM
lexizpimpin
but my foam looks similar to your can you highlight my picture where i should remove the foam that would be great thank you guys
Old Jun 10, 2008 | 04:28 PM
Fasthotrod's Avatar
Fasthotrod
Not from this computer, I can't...
Go back and look at my picture.
In the first picture with the full door, notice that in the lower right hand side the Ensolite has been completely compressed into the door compartment. This is the place where the door Styrofoam is pressing into the door cavity. Yours isn't even compressed in that area.
If I were you, I would remove the window switches from the door panel and try to put the panel into place. Use an inspection mirror to see where you are binding up. (Make SURE that you are putting the door panel down on to the door all of the way.)
Double check that all of the door panel alignment pins are aimed directly at the holes, and that the holes are NOT covered by damping/Ensolite. (You can see most of mine... they are the white dots along the black door.)
I'll bet you find that the door panel is hanging up at the top of the midrange driver. If you need to be sure, just remove the speaker pod and try to install the door panel. If it fits, you just found the sticking point.
I can't really tell you where it's binding up if I can't see it... so just take some time to get a feel for where it's hitting. Good luck.
Mark
Old Jun 10, 2008 | 04:51 PM
lexizpimpin
the problem is it doesnt fit on up top not on the bottom
Old Jun 10, 2008 | 05:03 PM
Kale's Avatar
Kale
Are you sure the pins are lining up? I have to hand guide mine in.
Old Jun 10, 2008 | 05:17 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
i agree ihave to hand line up pins alot
Old Jun 10, 2008 | 05:36 PM
lexizpimpin
Anyways i got some great news i was on the phone with John from Cdt Audio And they are sponsoring me so i will be recieving my new set of Cdt eurosport 642i component speakers i am very excited because these are top of the line speakers from cdt
So i will be waiting for the shipment from cdt and i will keep you guys updated for now i will be deadening the other door and the interior
as i am still waiting for my power wires and my monster cable
i will keep everyone updated
Old Jun 10, 2008 | 05:53 PM
DPG's Avatar
DPG
St. Jude Donor '06
thats cool, keep us updated.
Old Jun 10, 2008 | 05:58 PM
  #33
Kale's Avatar
Kale
Cool, so they are giving you free speakers? noice.
Old Jun 10, 2008 | 07:07 PM
  #34
lexizpimpin
kind of since i already paid for these its not really that much of a trade of but yeah lol
  #35
lexizpimpin
im planning on competing in sq competitions hopefully
Old Jun 10, 2008 | 07:08 PM
  #36
lexizpimpin
i dont understand the pins you guys are talking about i put the door panel on on top first and then i align the metal pins to the door and then i kinda push on the door panel from the top for it to seat and it feels as if there is something holding it back
Old Jun 10, 2008 | 07:12 PM
  #37
lexizpimpin
also if anyone knows what could be the cause of my window wiggling around when its up or down like to the sides ??
To Insane Work In Progress Sq Build
Old Jun 10, 2008 | 07:37 PM
  #38
Team DCA's Avatar
Team DCA
Maybe we'll catch each other at a show this year.
Old Jun 10, 2008 | 08:10 PM
  #39
lexizpimpin
Sounds like a good idea it will be my first at sq competitions i was mostly at show and go type competitions with my old car =] but i had alot of experience with high end car audio in the past
so this will be defenatly something new for me
Old Jun 10, 2008 | 11:29 PM
  #40
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Check the window track adjustment (under the door itself behind a small rubber trim piece.
Looks like this and the bolt is a 10mm
