Sponsored by: Innova
Insane Work In Progress Sq Build
Old Jun 5, 2008 | 11:54 AM
lexizpimpin's Avatar
lexizpimpin
Default Insane Work In Progress Sq Build
hey my name is alex i will be building my system in my 99 frc and its all for sq nothing more
I will try to document everything as good as possible but here is the stuff thats going in for now
Avic-d3
Cdt Euro Sport 3 way components-Front Stage
jl 10w7 for sub stage
Elemental Designs 9.2x for the front stage and sub stage
Knu Conceptz Wiring
Elemental Designs 100 sq of v2se
Elemental Designs 50 sq of v4
here are some pictures enjoy
Old Jun 5, 2008 | 12:18 PM
DPG's Avatar
DPG
St. Jude Donor '06
awesome, definitely post them pics of progress and such
Old Jun 5, 2008 | 12:31 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
must see more pics NOW lol
Old Jun 5, 2008 | 12:45 PM
lexizpimpin
lol Im guessing both of u guys know exactly what the components are and how great of sound quality they are but ohneslty iused a set of 6.2 dls irudium speakers in my old car i loved them to death but i used these cdts with no amp powering them and they werent really that great but thats possibly because there was no amp
Old Jun 5, 2008 | 12:56 PM
Kale's Avatar
Kale
Well DLS iridium speakers are much better than the CDT Vifasports... But the amp will make them sound notably nicer than they sound now for sure. Plus a 3 way needs a bunch of extra tuning sometimes.
Old Jun 5, 2008 | 03:50 PM
DPG's Avatar
DPG
St. Jude Donor '06
cdts really shine once you amp them especially a 3way. but i have seen the light of going active and will never turn back
Old Jun 5, 2008 | 06:46 PM
lexizpimpin
hopefully they will sound good once each side gets 200 rms
i just bought monster cable twisted wire for the speaker wires and i got some monster cable banana plugs hopefully will look very clean
Old Jun 5, 2008 | 08:31 PM
Kale's Avatar
Kale
do they put that stupid plastic wire in the middle of the monster cable that makes it look heavier duty than it actually is still?
Old Jun 7, 2008 | 07:47 PM
lexizpimpin
i just got an update the weather was toooo hott i only got 1 door done with elemental designs v1se and elemental designs v4 teklite ran monster cable wires mounted cdt euro sport mids and woofers but im having issues with the door panel going on if anyone can suggest which part of the deading to take off for the door panel to seat please let me know thanks here are the pictures
Started with the v1se
pictures of the goodies =]
v4 teklite installed
speaker pods
pictures of the bad boy Cdt euro sports
door panel got a layer of v1se and v4
door got finshed with the v4
Monster cable speaker wires
door all done with cdts installed
and last a pic of the rear =]
Old Jun 7, 2008 | 08:31 PM
openhelix's Avatar
openhelix
looks great!!
Old Jun 7, 2008 | 11:07 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
....and...subscribed.
Monster cable !!! nice (I used it too )
Old Jun 8, 2008 | 12:24 PM
lexizpimpin
i need a picture of someones door insulated because i want to see what part of the deadeing i need to remove for the door panel to seat properly
Old Jun 8, 2008 | 12:51 PM
Kale's Avatar
Kale
If that foam is 1/4-1/2" thick or thicker, its probably colliding with the Styrofoam on the back of the door panel. I had that issue when I put 1/2 oc foam on mine.
I ended up replacing the rubber moisture plug with a board to stiffen up the door (you MUST heavily paint the exterior facing side) and removing the Styrofoam.
Old Jun 8, 2008 | 01:26 PM
lexizpimpin
any pictures of what you are talking about also would there be any benefits of going with the board and loosing the styro foam?
Old Jun 8, 2008 | 01:35 PM
pentavolvo's Avatar
pentavolvo
also jsut an fyi if your speaker plates are a big too big they will hit the window/lock controls, been there and done that
Old Jun 8, 2008 | 02:12 PM
lexizpimpin
so what would be the best size for the speaker bracket? and also if i do take out the rubber stuff and replace it with some wood or w.e you guys recommend any pictures of that and benefits
Old Jun 8, 2008 | 02:14 PM
Kale's Avatar
Kale
Board will stiffen the door. You haven't added any stiffening material, so it would be a good benefit for you.
your speaker plates seem to be ok.
To Insane Work In Progress Sq Build
Old Jun 8, 2008 | 02:16 PM
pentavolvo's Avatar
pentavolvo
well if the speaker plates are the problem try puttin the door on without the window switches and it will go right in then just trim the one corner down a bit on the speaker baffle
Old Jun 8, 2008 | 02:27 PM
lexizpimpin
no it seems as if there is a problem on the top portion
the speaker plate is a bit of problem but not in that sense
i belive i put to much stuff on the top portion thats why i was looking for pictures of how ppl dynomat the doors thanks
Old Jun 9, 2008 | 01:05 AM
lexizpimpin
anyone?
