is the window wiggling side to side or front to back in the door? If it's moving front to back it sounds like the mounts at the bottom of the glass are loose. I believe the adjustment above is for side to side mvement. Don't try to remove all play from the window, because then the glass is forced to absorb the shock of closing the door. You will very quickly be out $298 for some new glass and have a large mess to clean up.
Update I recieved some stuff from Knukonceptz (Ring Terminals) and StreetWires Fuse Block-Distribution Block which was btw discontinued and very hard to get and i got a couple of things done today
Applied v1se on the whole trunk only 1 layer and 1 layer of v4
Ran the 4 gauge Knukonceptz power wire from the battery back used the gm adapter and the 4 gauge terminal
And the Knukoncepts Wire terminals
Also recieved this amazing Fuse Block-Distribution Block by Streetwires
Another update Recieved the new Cdt Eurosport 642i
here are some pix comparing them side by side to the old eurosports
the main difference is the mid is smaller then the old one
but the new drivers are beefy as hell and the tweet is bigger on the new set its the upgraded tweet not the 1 that comes with the es-642i
painted the subwoofer box red and placed the mirrors on the inside with the epoxy
and here it is wiith the front cover
side boxes that will house my crossovers here is the back of the little box covered in suede
My gf vs the w7 lmao
and a NSFW pic
From: ECS : WTF did you break now and HTF did you break it this time
I'd really like to compare my 12 inch with the sub on the right in that comparison
I'm curious to hear the CDT's and compare em to my polykevlars with no deadening in my car because I don't feel like adding the weight and I'm not competeing. Shoot me a PM whenever you get that sucker done...
not a problem at all ill pm you my number we can meet up and you can check it out
Btw my project is coming along great i just have a few words to say about cdt audio if you ever need anything from them please call and speak to john he is the man
i had an issue with the crossover on the cdt`s he took care of it no problem any questions i have he is always willing to help and always giving me great advice as far as customer support cdt audio is amazing
if i had to rate them i would give them 100 out of 10
anyone who wants to hear the speakers is more then welcome to come check them out the sound system should be done in a few weeks
btw here are some pictures of the sub box in its finishing stages
