Sponsored by: Innova
c4 audio/electronic
Old Aug 8, 2008 | 01:20 AM
totojim's Avatar
totojim
8th Gear
Default c4 trouble in stalling sony cd,finding bose receiver
91 vette Installing sony record changer.How do i get to the bose receiver to hook up antenae wire from fm modulator.Or is their an easier way? What does the receiver look like.I have the electrical intelligence of a dead monkey,please make it simple.THANKS
Old Aug 8, 2008 | 02:19 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
You want the CDM, which is located in the dash on the pass side of the car. To get to it, you must remove the fuse panel on the side of the dash. Remove the door, and then the surround, which is held on by three 7mm bolts. Next remove the hush panel, which is the panel under the dash, by your feet. Next remove the air vents on the pass side dash, two screws I think. When you look down into the opening were the air vents were, you should see a silver box; this is the CDM. The antenna plugs into the right side, near the front.
Hope this helps.
Randy
Old Aug 8, 2008 | 03:01 PM
totojim's Avatar
totojim
8th Gear
Hope this helps.
Randy
Many THANKSI see the antennae in the side of the cdm,now how do i get it out.I tried using a long screwdriver,no luck
To c4 audio/electronic
