Sponsored by: Innova
Easy Question
Old Sep 2, 2008 | 10:53 PM
IDM's Avatar
IDM
Default Easy Question
Okay so I have run a 0 gauge wire from the optima battery through the firewall grommet to the rear of the trunk on my C5.
That is for the amps/sub
Do I need to run a power wire from the battery to the headunit or use the factory power wire from the old bose harness? It is a double din nav/dvd player and Ive run new wires for each of the new speakers too
Old Sep 2, 2008 | 10:58 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you can tap old harness or just go to passenger kickpanel and pick up accesorry and constant power from the 3 wire harness there
Old Sep 2, 2008 | 11:00 PM
IDM's Avatar
IDM
there is no benefit to giving the headunit more power directly from the battery with thicker wire?
appreciate your reply.
Old Sep 2, 2008 | 11:18 PM
pentavolvo's Avatar
pentavolvo
not really since u have amps the radio is just supplying a signal, im sure someone will jump in and say run a wire but u will gain nothing
Old Sep 3, 2008 | 08:22 AM
thmupr's Avatar
thmupr
Power wire is fine, just run a new Ground to a metal ground source, or to the battery or amplifier if you get noise.
Old Sep 3, 2008 | 09:29 AM
Fasthotrod's Avatar
Fasthotrod
I'll add to Thmpur's comments and say that you should upgrade the grounds as well. Run the same gauge from your battery to the frame, and make sure that you clean the frame such that there is NO paint between the frame and ground lug. You can use some "No-Ox" if you are concerned with oxidation.
I would also upgrade the ground between the engine and the frame. Consider upgrading the wire between the alternator and battery if you are drawing high current levels. (I would fuse it on each end, just to be safe.)
Remember to post pix after your install is complete.
Mark
To Easy Question
