Sponsored by: Innova
Please help with 5 Channel Amp
Old Nov 9, 2008 | 09:26 AM
vr6aaron's Avatar
vr6aaron
Default Please help with 5 Channel Amp
Okay I have Memphis 5 channel amp and here is my problem.
I have been using the 4channel part for a while now and I finally got around tohooking up a sub. The problem is I am getting no signal or a very faint sound out of woofer.
I checked connections everything is fine but can figure out why I cant hear it.
I did notice an sub input for a mono rca, do i need to run a rca to radio to get a signal? Or do i just have a blow 5th channel?
Old Nov 9, 2008 | 10:48 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
prly need to hook up rca to the 5th channel, or is the gain not turned up
Old Nov 9, 2008 | 12:51 PM
vr6aaron's Avatar
vr6aaron
The gain is full blast. But i dont even think I have a sub connection on my Kenwood. Ill check it out.
Old Nov 9, 2008 | 03:05 PM
pentavolvo's Avatar
pentavolvo
there might be a switch on ur amp to adjust what rca's feed what, otherwise a pair of splitters on the rear channel rca's woudl help, also you dont wanna be running it with the gain maxed
To Please help with 5 Channel Amp
